iFive Mini 3GS RileyROM 1.5
    One user reported that when the battery finally ran all the way down, it eventually reset. I had to do it one time by removing the cover and disconnecting the battery...but I don't recommend that.
    Sent from my P1 using Tapatalk
    I'm stuck in the same situation as chris1 and didnt want to wait until the tablet reset after battery drain.
    can you please give me some info on hot to open the tablet and disconnect the battery? i'm quite skilled in opening phones and other electronical devices, i just would like to have info. online i havent found any tutorial..
    thanx for your help.
    Francesco
      On this tablet, you have to open the tablet around the front...taking care not to damage the screen. Just use a thin knife blade to get started and a guitar pick to hold it open.
      When you put it back together, make sure the heat sync tape is secure over the CPU. You will get a screen flicker until you press firmly to get things back to normal.
      Randy
        Has anyone tried v1.5.2? It's working just fine on my tablet. I'm glad to finally be able to run Titanium backups.
        Randy
          I have random reboots, and yesterday it sucked the battery completely on standby
            I'm using 1.5.2. Thanks for get TB working.
            I've have random reboots about once per day, it hasn't been when actually using it though, only when the screen is off.
            Has anyone gotten Xposed with Gravity Box to work? Pre v1.2 it used to work, but not anymore. Xposed installs, but after the status & navigation bars randomly disappear. GB doesn't work at all.
            Any thoughts?
            Sent from my Nexus 5 using Tapatalk
              Re: iFive Mini 3GS RileyROM 1.5
              Any thoughts?
              Same problems here.
              Battery drain I think is related with GSM part.
              On fly mode, with Wi-Fi on, I got good battery life.
              Enviado desde mi ZOPO 980 QUADCORE con el fabuloso KitKat 4.4.2 by paolothlw8 ANDROIDIANI.COM
                Is there a way to increase the screen brightness (beyond the brightness level in android)?
                  Hello I am new to the group which I might say the process to install the 1.5.2 rileyrom​​​
                    Just follow instructions in post #1 on this thread. It is a different ROM but up to date instructions.
                    Randy
                      [Quote = rrileypm; 237015] Sólo tienes que seguir las instrucciones en post # 1 en este hilo. Se trata de una ROM diferente, pero hasta la fecha las instrucciones. http://www.FreakTab.com/showthread.php?t=18182 Enviado desde mi P1 utilizando Tapatalk [/ quote]
                        work grate for me
                          Same for me, It is extremely stable and I have been testing many things with it. Never had it crash, hang or reset while I was doing something
                            v2.0.2 is out now
                            waiting for Riley version
                              Can you provide a link to the update?
                              Randy
                                Update to 2.02 was very small about 8 MB? (fast look when start downloading) maybe so small update ,they dont put 2.0.2 to site?
                                I get the OTA notification update, success downloading but fail to install
