iFive Mini 3GS RileyROM 1.5
Re : iFive Mini 3GS RileyROM 1.5
Originally posted by chris1 View Postok, how to make it empty?
48 hours and mine still dont work cause battery not empty?
I read on a forum (here or xda) about a guy who had given up and was packing the tablet for RMA and who tried one last time...and it worked ! So don't give up too soon and keep trying.
You might see if your tablet has shutdown or if it's still stuck by plugging it to your charger and see if led turns on.
Hopeful thoughts
i tried other way and i left the tablet charged all night, still nothing, now when i connect tablet via USB to windows 7, no more sound either
No charging led turn on either
Now i have to wait weeks when battery empty again...
Hopeful thoughts
Originally posted by chris1 View Posti tried other way and i left the tablet charged all night...
I've updated this to v1.5.2.
Just go to post #1 of this thread for v1.5.2 with Koush Superuser, instead of SuperSU which fixes the ability to run Titanium Backups.
I've fought sd card permissions for weeks and I ran across a post on another site that noted that MTK devices can't run Titanium with SuperSU. I've tested this extensively, and no more "insufficient space" errors when creating a backup.
I mainly did this for me...but I'm sharing my new version with everyone.
You only need to flash the system.img and boot.img in download only mode, if you like. If you do it that way, you won't have to reinstall all of your apps/data.
When you run Titanium, though...you will get a warning window saying that you may have problems with this version of Superuser...but just ignore it. There's a box you can check that makes the message go away for good.Randy
I am going to flash with the 1.5.1 now, just confused if I have to use download or Format all +download ( per instruction)? I made a backup of NVRAM/IMEI via the toolkit.
If I use format and download would be able to easily restore the backup via mkt toolkit again?Last edited by benzz; 10-03-2014, 07:34.
Just use download only. If you choose a different set of EBR files, you need to do a wipe/factory reset in recovery. Its a good idea to backup your NVRAM data just in case.
Sent from my P9Randy
Yeah I tried it that way.
Although i had to flash with 1.4 first as flashing with 1.5 first time corrupted the flash same way as it did for another user in this thread. but using download only from 1.4 to 1.5 did work
Is there a way to make your logo portrait than landscape as how it is now?
Or remove the second logo ( i quite like the first one but not fond of second one)
Maybe next time. I usually use my tablets in landscape. That first logo is in the logo.bin file...maybe I can do one in portrait as an option.
The boot animation is located in system/media.
Don't just delete it...cut and paste it somewhere on your sdcard. Otherwise, it might corrupt your system.Randy
Yes, it will work. As long as the screen resolution is correct, and the proper permissions are set for the new animation.Randy
There are currently 2583 users online. 5 members and 2578 guests.
