Just another CLONE?
Originally posted by adzo73 View Postcan anyone tell me if my M8 is a clone please?
He tried flashing megatron rom and it seems its bricked. Blue light still on.
Defo a clone, anyone seen this version before?
Originally posted by KainXS View Posthmm can someone tell me if this is a clone and if its not can I install finless on it.
Hynix Flash
Samsung Ram
BUT the date is wierd it says 201/03/12
heres my pic of my,
Im assuming mines is also a clone. Ive tested a few roms on it without problems.
Hello, i have also a clone m8s device, and have tried to update the device but it got stuck. Now i have black no video output and only the blue light burns. I have tried several images, but nothing seems to work. Does any one got a solution for me?
https://www.dropbox.com/s/jyevvqovml...31531.jpg?dl=0
Originally posted by nei-k View PostI share photos with my M8S Amlogic S812 2GB+8GB AP6330 clone i bought 8 months ago from aliexpress for 60$
Full specs can be found on specdevice
It cames with firmware KOT49H.20150728. It is fully compatible with all ENY M8S firmwares that I've tested
After many trials i managed to install latest Android Lollipop from Tronsmart MXIII Plus 106L1_151029
Everything is working fine with this firmware, except from original remote which didn't bother to fix, since i am using an airmouse!
Bigger pictures here: http://imgur.com/a/U42qB
I opened my M8S and the built is exactly like yours. It came with KOT49H.20150307. I just bricked my box last week and it was really unfortunate that I never backup the rom. I unbricked the box with a few firmwares I got from the net, but I still can't find the firmware that fully compatible with it. Appreciate if you can point me to where I can download the firmware that compatible with this box.
Thanks.
i got a bricked m8 dont know if this is a clone hopefully someone can tell me what firmware to use or give me the right stuff to unbrick it i'm almost ready to smash it up with a hammer
https://www.mediafire.com/folder/olu.../m8_box_images
[ATTACH=CONFIG]n601765[/ATTACH] [ATTACH=CONFIG]n601766[/ATTACH] [ATTACH=CONFIG]n601767[/ATTACH] [ATTACH=CONFIG]n601768[/ATTACH] [ATTACH=CONFIG]n601769[/ATTACH]You may only view thumbnails in this gallery. This gallery has 4 photos.4 PhotosLast edited by g2147; 07 October 2016, 14:58.
Originally posted by beats View Post
That box is fine I have firmware for it that works very well or Stanes Linux works good for it, all the m8 are basically the same whoever you but from just need a decent firmware.
[ATTACH=CONFIG]n601922[/ATTACH]
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by g2147; 08 October 2016, 00:58.
Try this method for unbricking M8s n200 kot49h.20150728,no blue light.Won't go into recovery.
worked for me but if your box is bricked won't harm it to try.
https://www.dropbox.com/sh/0h7011p5u...5ShpBXcQa?dl=0Last edited by jimchass; 24 January 2017, 10:25.
There are currently 1660 users online. 0 members and 1660 guests.
