.gif)
Just another CLONE?
Originally posted by hsia View Postha ha
why is it poor quality hsia can you explain to me ? why do you rubbish other companies its not the first time?Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postwhy is it poor quality hsia can you explain to me ? why do rubbish other companies its not the first time?
maybe i made a conclusion too early....i withdraw.
of course it will not work it 1gb ram and 2.4ghz, it doesn't mean it is poor quality, it just means it has different spec hardware. and mine or fineless roms will not work as roms we have are for ap6630 and 2gb ram.
also what amuses me is a clone from a original, is orginal but clone from clone is notBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postof course it will not work it 1gb ram and 2.4ghz, it doesn't mean it is poor quality, it just means it has different spec hardware. and mine or fineless roms will not work as roms we have are for ap6630 and 2gb ram.
thanks for your remind
Originally posted by wilx View Post[ATTACH=CONFIG]9225[/ATTACH]
I bought this off ****, and obviously it is a clone, the 5G wifi is not working ( my other M8 sees the 5G fine).Anyone know if flashing a new firmware will sort the 5G? and if I can use any firmware found on this forum?
Maybe I am just better sending it back
what firmware does it have check in setting the chips does support 2.4GHZ/5GHZ ap6330Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postwhat firmware does it have check in setting the chips does support 2.4GHZ/5GHZ ap6330
KOT49H.20140826 test-keys
Kernal 3.10.33 rurp@rurp-buildserver #1 Tue Aug 26 10:38:29 HKT2014
Where in the settings do I find if it supports 5G?Maybe its the really poor aerial that's the problem?
I don't know what's going wrong with this pcb/fw, but at the picture I see the AP6330 which is able to handle also 5GHz....RK3288 Devices
- Overview BOX (LINK !)
Originally posted by okey View PostWell i have just brought a new one off ****, and seems to work fine, does not have samsung chips tho.
Is this a clone???
your one is old V92 +same Nanya ram chips but different IR board and wifi antenna compare to the original boxLast edited by TMx; 24 December 2014, 15:00.
There are currently 3518 users online. 1 members and 3517 guests.
