Just another CLONE?
it is clone one
Originally posted by vik2009 View PostI have one H8&M8 V2_0 20140708, like you.
It has ROM "MODEL K200 - Android 4.4.2 - Kernel 3.10.33 - Build KOT49H.20140725".
[ATTACH=CONFIG]8163[/ATTACH]
I've bought this tvbox to Bluetimes store.
http://www.aliexpress.com/item/Bluet...954157199.html
now also in the market, some clones printing with M8/M9 V0.92 or sth else,
but when you play with DTS movie, no sound output at all.....so , also check the box at your hands with DTS movies, play with mx player or video player to see having sound or not
i once asked acemax they selling clones or not, they said: saying clones by acemax is a insult.....so i trust....
Originally posted by 2sppandey View PostGuys is this a clone...??
The four black chips say samsung 428
by the led light it says H8&M8_IO V2_0
[ATTACH=CONFIG]8911[/ATTACH]
Originally posted by beats View PostI wouldn't worry about who makes it as quality isn't any better from one seller to the next just which firmwares are compatible and that board will take any of one's on this forum I believe
Originally posted by 2sppandey View PostThats the main reason I wanna know...as want to know what stable firmware should I put on it...any suggestions..??
I haven't found anything that can beat stanes original mx Linux on this box yet.
No success in updating FW
Originally posted by beats View PostPersonally I think Linux is the only thing worth putting on the m8 if you have to have android and don't mind the few bugs then stanes or just me roms.
I have tried Finless 1.8 and Stanes Android using toothpick method. With Finless 1.8, nothing happens i.e., the device comes up as I received it out of the box. With the Stanes Android, after power up (with reset pressed), the Bluetimes logo appears and when I release the rest, the Android logo appears. However, the install does not complete i.e., after 15 seconds the progress (blue) bar stops moving and nothing happens. When I restart, I get back to the original startup screen.
Any Help would be appreciated.
Originally posted by dhirenpaul View PostI have an M8 (model is Best-M8). Comes up with 'Bluetimes' logo. Single band 2.4 GHz Wifi. The PCB is H8&M8_IO V2_0 20140730. Has Samsung memory. I have spent a lot of time trying to update the FW because (a) the Wifi performance is very poor and (b) the box is not very stable i.e., reboots once in a while.
I tried openelec and it didn't work. Tried other firmwares, and the progress bar freezes in installation process always.
At this point the unit boots into recovery.
I asked the seller for the stock firmware to this model to restore to the original state and he sent me this:
cyx_h8_ap6181_140903_8g1g_蓝色时代.rar
When i was doing the update, when powering the unit with the reset pressed, the unit won`t power on anymore. Blue light is off.
any ideas?
thank you.
any ideas?
thank you.
any ideas?
thank you.
Update: never mind, I have found a link,
There are currently 2732 users online. 1 members and 2731 guests.
