Just another CLONE?
Originally posted by beats View PostSo what do you class as "Genuine" exactly as I have had a Board from ENY without samsung RAM and board from elsewhere with samsung ram.
Originally posted by jimmyx View PostThere is now an M8N version on the market from ACEMAX to combat Clones... comes with a new controller ETC. I will post pics of said unit once my first 100pcs arrive early next week
as far as I understand they released this firmware/ hw revision to combat all the clones... so their official FW's for the units WILL NOT WORK on the cloned units.
I do not see why roms like BOBs finless would not work. Ive asked them directly, I should have a response within the hour for you.
Originally posted by jimmyx View PostI need to load a new remote.conf?
or this is IF i load something like bobs finless etc?\
Yeah I am sure finless 1.8 has the old file.
Just copy from firmware on your new box and replace on finless ROM - you will need root explorer though or what I seen today was a post from just me doing this a different way SD card / pin in back.
Originally posted by Droid-TV.fr View PostHi everyone,
For those who have the following M8 model (M9&M8_TVBOX_V01_0728) :
[ATTACH=CONFIG]8253[/ATTACH]
If you tried the Finless 1.8 ROM, your device might be stucked at the splash screen. I have dumped the stock firmware if someone need it (kot49h.20140915 test-keys) : https://mega.co.nz/#!dsMRkJQb!QWdK0B...cMOOJ8G4iKNJ-M
To use this firmware :- Copy contents of the archive to the root of a SD card
- M8 turned off, insert the SD card
- Use toothpick method to access the recovery menu (actually it will be TWRP, thanks abdul for this great tool)
- Choose the "Restore" tab, then choose "External SD" and access to the folder where all the files are (/BACKUPS/k200/KOT49H...).
- Select every files (check also MD5 verification) and launch the recovery
- Once it's done, select Reboot
- ... and I hope your M8 will work again
I hope this will be helpful.
I restored my M8 (M9&M8_TVBOX_V01_0728), but now my box freezing every minute,and restarts. What can be wrong?
Originally posted by Grach13 View PostI tried factory reset. What about another restore? Is there another working firmware for this version of M8?
I am testing several roms now. Only Linux XBMC works well for the moment (wifi is working)
EDIT : This one from JustMe works also, maybe you should give it a try.
Originally posted by Droid-TV.fr View PostAbout another restore, I was thinking of doing the restore again.
There are currently 2295 users online. 0 members and 2295 guests.
