Just another CLONE?
Originally posted by ALP View Post
Originally posted by mag_freak View PostRK3288 Devices
- Overview BOX (LINK !)
Originally posted by ALP View PostFriends;
i open my M8 box, and power on. I see a problem in the PCB. I marked to green on the picture is too over-heated and i see smoke. Is anybody know what is the this chip?
[ATTACH=CONFIG]8185[/ATTACH]
That's your PMU or Power management IC, sounds like you burnt it out.
If you flashed an image thats not compatible and bricked your deivce like I did it killed the PMU replace that and you'll be back up and running.
Stock firmware for M9&M8_TVBOX_V01_0728
Hi everyone,
For those who have the following M8 model (M9&M8_TVBOX_V01_0728) :
If you tried the Finless 1.8 ROM, your device might be stucked at the splash screen. I have dumped the stock firmware if someone need it (kot49h.20140915 test-keys) : https://mega.co.nz/#!s8kzDDCQ!b9Vh8-1U6o6MQzFF8XIQpUvUNlxQgIamO58jy9D9fJA
To use this firmware :- Copy contents of the archive to the root of a SD card
- M8 turned off, insert the SD card
- Use toothpick method to access the recovery menu (actually it will be TWRP, thanks abdul for this great tool)
- Choose the "Restore" tab, then choose "External SD" and access to the folder where all the files are (/BACKUPS/k200/KOT49H...).
- Select every files (check also MD5 verification) and launch the recovery
- Once it's done, select Reboot
- ... and I hope your M8 will work again
I hope this will be helpful.Last edited by Droid-TV.fr; 16 October 2014, 11:53.
please help
Thanks for reply. I am afraid, my PMU is burned. I saw spark on the PMU. What can I do? This tv box is only junk???
Originally posted by beats View PostThat's your PMU or Power management IC, sounds like you burnt it out.
[ATTACH=CONFIG]8253[/ATTACH]
If you tried the Finless 1.8 ROM, your device might be stucked at the splash screen. I have dumped the stock firmware if someone need it (kot49h.20140915 test-keys) : https://mega.co.nz/#!dsMRkJQb!QWdK0B...cMOOJ8G4iKNJ-M
I hope this will be helpful.Thank You! I had (soft brick) stuck at Finless splash screen and this method worked on my box. It is now at factory settings and working perfectly! Can you please tell me what rom works on this box, I have hard bricked another box flashing the wrong rom and burned out the board. The factory rom does not have root and I have not been able to get root access on this box because the firmware is just to new. Any ideas??
Originally posted by jamesshot View PostThank You! I had (soft brick) stuck at Finless splash screen and this method worked on my box. It is now at factory settings and working perfectly! Can you please tell me what rom works on this box, I have hard bricked another box flashing the wrong rom and burned out the board. The factory rom does not have root and I have not been able to get root access on this box because the firmware is just to new. Any ideas??
You can use Bobs easy root on it found here -
Originally posted by ALP View Postit looks like it is impossible for me. I suppose that i need i new one.
Please take me a piece of advice, which brand and model have you suggest?
Originally posted by beats View PostYou can use Bobs easy root on it found here -
http://www.freaktab.com/showthread.p...oot-ZIP-update
Originally posted by jamesshot View PostThanks again! The firmware works great and Bobs easy root worked perfect! I assume that the other box I flashed, and wont even power on any more needs to be repaired? Anyways I have a good working M8 box now but the Google Playstore is very limited. I tried using market helper and renaming my device but still no go. I cant event get simple apps like facebook, vevo, ect..... What rom are you using and how can I get full playstore?
Did you try the "Aptoide" app? It is already installed on M8 box and some app that you can't install using Google Play can be installed with Aptoide.
(And I'm happy that your M8 box now works again! )
I am about to order 5 M8's. And this is the pcb picture I got from the seller. http://kfdown.a.aliimg.com/kf/HTB11o...Xq6xXFXXX9.jpg
Is that a genuine one and will all the firmwares on here work, like stane and stane linux and Acemax?
There are currently 1178 users online. 1 members and 1177 guests.
