How to unbrick Your M8, M8N, H8M
Originally posted by polys View PostOk thanks for the info. So how do I do that and what pins do I need to short?
this is the thread i helped someone else with all the info you need is there
Originally posted by grant2258 View Posthttp://www.freaktab.com/showthread.p...uare-need-help
Originally posted by polys View PostI'm trying to follow that thread but i'm not really sure where to start. Putting on the SD card - which i created with bootcardmaker (using uboot.bin in amlogic root) - your recovery.img and any zip file with the proper factory_update_param.aml doesn't do anything.
Your box is broke or bricked. short the nand pins with this memory card in hold in reset and power up. I need to look more into the default names of files on the sd card I know you can attach a tty to set the env varaibles to boot a particular kernel but donrt worry about that part. after you see the failed recovery screen take it from there. Also copy the u-boot.bin onto the sdcard as well ass adding it with bootcardmaker. That is supposed to boot the recovery.img not seen it working properly yet though just maker sure my u rename my bootloader.img to u-boot.bin is all you need to worry about if you want to try stock install if it fails like i think it will just use the probox imageLast edited by grant2258; 12-27-2014, 18:46.
Originally posted by polys View PostI have blue light on the box. It just won't show anything on screen and won't boot into recovery. What's the process I should follow?
1) get am tools
2) downoad my recovery.img and and bootloader.img from the other thread
3) rename my bootloader.img too u-boot.bin
4) start bootcardmaker
5) pick your sdcard drive letter (make sure its the right letter or youll ruin you hard drive partition you use)
6) tick yes to format and partition
7) click open and pick my u-boot.bin
8) press make ( press start when the dialog to format comes up)
9) download finless 1.8 if you dont have it
10) copy the following to your sdcard you just formatted with bootcardmaker
em8_finless18.zip
recovery.img ( the one from my other thread)
u-boot.bin (my bootloader.img you renamed to u-boot.bin)
(eject the sd card from windows) remove
11) put the sdcard in your m8 hold the recovery pin down (at least 30 seconds) dont worry about no display wait 5 minutes for flash to install if its working it will reboot within that time
12 if nothing happens do the same with the nand pins shorted ( 17 and 18), reset button in and power on.
edited to fix short locationLast edited by grant2258; 12-28-2014, 12:11.
em8_finless18.zip
12 if nothing happens do the same with the nand pins shorted ( 7 and 8), reset button in and power on.
had to get gimp to edit the image not used it befofre so im no artist. You will see some refer to pin 17 and 18 its all the same if you count it from the wrong side its 17 and 18.
Originally posted by grant2258 View Posthad to get gimp to edit the image not used it befofre so im no artist. You will see some refer to pin 17 and 18 its all the same if you count it from the wrong side its 17 and 18.
Put the memory card in you made earlier keep the reset button in short the pins then power up pins should be shorted at all times. Then the box should boot recovery with the card in u made even if it's just shows failure. Did your box fail an update or was there some other problem. You could have blown the hdmi If the tv and the box where on when you plugged the hdmi in.
In my experience if your really hard bricked and have to short pins, the recovery wont come up. Only the USB port will come up in which you can then use the flash tool. Oh and you need to have the jumper jumped to enable the USB port. This was for the ENY/Acemax M8.
Also for me it is not 7&8 counting down from the chip. It is 7&8 counting up from the bottom (as I recall that's 17&18 when counting down from the top??? but I do not remember now).
The recovery shows up and fails if you put a bootloader and that recovery.img with boot card maker and a working uboot on a ott box. The jumper isint needed on the ott box for usb either and the box won't boot Into recovery with the sd card with the jumper on but it will with the jumper off. I think it's something else going on with the box though cause it did flash the probox2 image 100%. The best he can do is hope the nand was corrupt and flash via usb after doing the short. The thing is this changes from box to box. I think I'll remove the bootloader images from now on when updating cause that seems to be the bad apple for the other boxes. I'm going to get a usb tty and see if it's hooked up on my box and see what's going on when a bootloader is on the sdcard
There are currently 2815 users online. 6 members and 2809 guests.
