I'm more than happy to do a pdf file with full instructions to assist
How to unbrick Your M8, M8N, H8M
No spam me can we get 1 thread seems to be allot of people lately posting same thing do you think maybe a sticky would be needed as you have done for the allwinner draco just a suggestion and feedback?
I'm more than happy to do a pdf file with full instructions to assistBugs are Sons of Glitches!
JustMeTags: None
- Stuck
Originally posted by hsia View Postimg software?
Sounds like a plan. Make sure to add if the box is completely dead to look up the nand data sheet for the right pins. I'm pretty sure it's the new bootloaders doing the dirty work is a common trick on dream boxes etc. Unless it's needed for drastic changes it would be best leaving it out of customs
Originally posted by JustMe View PostNo spam me can we get 1 thread seems to be allot of people lately posting same thing do you think maybe a sticky would be needed as you have done for the allwinner draco just a suggestion and feedback?
So now it's up to you (also the link to the img)
Originally posted by JustMe View Post1. get blank sd card 1gb or higher
2. load burnBootCard format sd and load the uboot.bin file
3 after load the .wps extention file on sd card via windows
4 place sd in device
5. short pins 17&18 of the tsop 48pin chip dot being pin 1 there is pictures posted here on forums
6. have jumper over otg port pins ( view photo)
7. get probex.img file ready from freaktab forums
8 open up usb burn tool & load the probex img file
9. have the reset button pressed while connecting power to the device
10. connect usb cable and wait for windows to reconise the device and for usb burn tool to show up hub it may take upto 1 minute while reset button is still pressed
11. then once reconised force flash
12. keep repeating the process you will get few percentage higher each time
I'm sure some posted on forum a methid could of been on another forum cannopt remember now when i get back home later today I am sure i saved the link could of even been no spam me
Originally posted by userofthenet View PostThank you so much Justme. I actually resurrected mine using only step 7 to 11. My img file was in the computer and it worked that way. It flashed 100% with the first trial.Originally posted by JustMe View Postthat is fantastic news well done
[USB Burning Tool with windows PC] http://www.tronsmart.eu/downloads/
=> http://www.mediafire.com/download/jm...ogic_tools.rarRK3288 Devices
- Overview BOX (LINK !)
Originally posted by TMx View PostHave you checked Probox 2 section?
Here is the link. Download the second one and it will give you the img file. http://probox2.com/category/probox2-ex-firmware/
Originally posted by polys View PostI'm getting this when i run the USB burning tool.
I'm on Win7 64-Bit
I'm on Win7 64-Bit
worked fine in windows 7 64 bit for me
this is a windows 7 ,8/ vista problem reboot windows press f8 while the bios screen shows and pick Disable Driver Signature Enforcement this is before windows boots your box will pickup then. The driver should load properly when you do this.
One thing for this information that should be clarified is the pin 17 and 18 thing. Im sure someone has counted the pins from the wrong dot ie a big dot marked on the chip instead of the little one. it should be pin 7 and 8 from the small do marker thats on the chip itself. Unless both work but i wouldnt imagine it would unless uboot detects something on these pins
There are currently 1490 users online. 2 members and 1488 guests.
