Post 335 lays out the difficulty getting into some tabs. I think this is where I got the info regarding heat guns being needed in some builds a bit more than others.
Cube T9 ROM/Tools/Mods, etc
Working TWRP
Here is working TWRP for Cube T9, uploaded to my Google Drive https://drive.google.com/file/d/0B_9...ew?usp=sharing
All credits for this goes to @ hanuma50 for developement and @helgiman for testing (both from 4PDA forum)
I have no way to edit/add to first post due to forum limitation.
Originally posted by Edius View PostHere is working TWRP for Cube T9, uploaded to my Google Drive https://drive.google.com/file/d/0B_9...ew?usp=sharing
Originally posted by flux1000 View PostHave you tried it? What is language used in the UI?
You don't trust us?
TWRP is in english and works.
Excuse me if you feel insulted in any way through this post.
You have any response from these spanish developers regardind TWRP for your T98?
You should try this ...It could work for you too.
I suppose it should work for T98 too, as Edius stated.
Flux1000, let us know!if you appreciate my efforts this is the link for any donation:
Please!
Last edited by BamaPanda; 06 March 2015, 12:28.Cube T9; Pipo M8 Pro (on life support); LG gPad
TWRP Instructions
Originally posted by BamaPanda View PostI need instuctions .....
1. Download TWRP_Recovery+CUBE-T9.rar in your PC link
2. Extract archive and you'll see MT6752_Android_scatter.txt and recovery.img files.
3. Power off tablet.
4. Open SP Flash Tool v5.1452.00 from my Google Drive link or any version of SP Flash Tool included in previous T9 ROM's V1.02 or V1.04.
5. Go to Scatter-Loading and browse for MT6752_Android_scatter.txt
6. All boxes must be unchecked, except recovery
7. Select Download only mode or Firmware Upgrade mode.
8. Click on Download.
9. With tablet powered off connect USB cable(do not use USB 3.0 port, only USB 2.0 ports are compatible) and you'll see progress bar working at the bottom of SP Flash Tool very fast ....at 100% you'll see a green check box showing Success.
10.Turn off SP flash Tool and disconnect USB cable from your PC.
Go to TWRP recovery from tablet Off state pressing/holding Power for about a second then press and hold vol+ until a menu displays at the bottom left.
Scroll through the menu options with vol+ and select with vol-.
You may need to know that OTA update will not work anymore with TWRP installed...only stock recovery will give you succesfully updates OTA.
To flash back original recovery.img do the steps described above (with original recovery.img from FW's V1.02/1.04) and OTA will work like before.
This TWRP recovery is the only way to backup/restore all partitions from T9 (including NVRAM) and to root with SuperSu avoiding chinese root programs.
Regards, Edy.
Originally posted by Edius View PostIn description I said "Working TWRP" and @Rabinowitz says "It works very well"
You don't trust us?
SP Flash Tool Tutorial
Needed tools:
Drivers,SP Flash Tool, ROM's and recovery
1. Drivers and SP_Flash_Tool_v5.1452.00 here
2. ROM's V1.02_2014.11.21 and V1.04_2014.12.30 here
3. TWRP recovery here
4. Original recovery (V1.02 or V1.04 - pair with flashed ROM version) here
How to:
First, one of the provided drivers pack need to be installed(link above).
1. Download in your PC FW V1.02 or V1.04 (recommended V1.04) from above link.
2. Extract archive and rename all folders in latin characters (original folder names are in chinese)...if you keep original folder names you'll get an BRom error from SP Flash Tool.
4. Open SP Flash Tool (from above link or from any factory .rar file)
5. Point to scatter file and all boxes from SP Flash Tool will be populated with files.(all boxes must be ticked)
6. Select Download only mode or Firmware Upgrade mode (I use Upgrade Mode)
7. Click on Download.
8. With tablet powered off connect USB cable (use only USB 2.0 port, USB 3.0 isn't compatible) and you'll see progress bar working at bottom of SP Flash Tool (at 100% will appear an big green box OK...that show your success) turn off SP flash Tool and disconnect USB from PC.
How to:
How to:
What about with TWRP recovery and original recovery - do i have to put these files somewhere? in your how to is no point about them, just in tools.
There are currently 2543 users online. 1 members and 2542 guests.
