Cube T9 ROM/Tools/Mods, etc
There are already devices with MT8752 with lollipop so for your T9 I think it's only a matter of time...if you appreciate my efforts this is the link for any donation:
ACUBE announcement to facebook
CUBE Tablet. Gefällt 1.985 Mal · 1 Personen sprechen darüber. The official Facebook page of CUBE/ALLDOCUBE Tablet
ACUBE
Hi, all the device with android 4.4 will update in the end of this month, i don't think the other brand has updated 5.1 even my samsung note don't have 5.1 update
ACUBE
For your information Teclast P98 4G that share the same MT8752 SoC is already available with android 5!
Other than that do you think that this update will be also available for cube talk 9x? (now cube talk 9x is on android 4.4, as T9)if you appreciate my efforts this is the link for any donation:
The other versions of the same tablet have not been updated and their unofficial update is very difficult.
I do not agree. The SoC is the same I'm almost sure that in the next future all other MT8752 will receive Android 5.0 updateif you appreciate my efforts this is the link for any donation:
Originally posted by snowglider View PostHi all,
i just bricked my T9 (No OS) and now i am searching for an UPDATE.ZIP to install the OS again via TWRP
It will be nice if somebody got this and will share it with me.
I did updates with Droid Tools, but i don't get access to the T9
Thanks in advance
Snowglider
Originally posted by devilz-wolit View PostXnetfoX eXtreme 1.3b108: First Custom ROM for CUBE T9 perfectly working.
- Based on 1.08 Stock Rom
- Root: TWRP Recovery 2.8.4.0 New, SuperSU 2:49 Pro and Busibox Pro 27.
- Eliminated all part of China
- New backgrounds, bootanimation, shutanimation, keyboard tones and some ringtones.
- New software added (Printing Devices, Battery Management, Rebooter, Root Explorer, State GPS, Maps, MyMaps & Navigation)
Updated Google Apps (Play Books, TTS, YouTube, Device Manager, Play Store 5.5.12 Mod, Talkback)
Browser replaced with a more advanced version.
Updated and available in offline mode all the vocals.
Unlocked writing on the external SD for apps not conform to KitKat and rewritten the hosts file.
Starting in Italian
As we are still far from creating an installer for recovery, (I hate to use SPFT if not for emergency case! And then with the advent of repartitioning us we must always remember to use the scatter right) I thought to overcome the problem and shorten time using a restore backup to be made by TWRP.
In fact it is as the software pre-installed on a series of identical machines using a system image appropriately created and since our tablet differs only by the partition NVRAM. (This partition will not be used in XnetfoX ROM)
Only requirement: TWRP Recovery installed
Take before a full backup of your ROM through TWRP (so if you do not like XnetfoX, you can restore your old ROM without losing anything)
Download the XnetfoX, extract the zip files on a microSD or a USB pendrive sure to have this structure: MicroSDRoot\TWRP\T9_MT8752\XnetfoX_eXtreme_13b108
Turn off your tablet
Insert the microSD or USB stick via OTG
Start in recovery mode
choose Restore
Tap on Select and select storage: MicroSD or USB-Otg
If you unzipped properly you read XnetfoX_eXtreme_13b108.
Tap above and you will see the selected components: Boot-Logo-Recovery-Uboot-System-Data
Take Swipe to restore
Restart the tablet
XnetfoX eXtreme 1.4b108
https://drive.google.com/file/d/0B0L...ew?usp=sharing
Corrected bug in GoogleTTS, Play services updated & integrated in system, New Google L keyboard with material design in options, Updates: Busybox & YouTube.
XnetfoX eXtreme 1.6b108
is out
XnetfoX eXtreme 1.7b108
... in test
all the updates in my full thread on androidiani
http://www.androidiani.com/forum/tut...ml#post6709867
*Use with any \data partition., So to install the TWRP do I just run the SP Flash Tool as per normal, un-tick all the other boxes apart from the recovery box, then replace that file with the win-image TWRP file that is included in the ROM download ?, What im a bit confused about is what is the scatter file for ?
Edit : No matter, I have sussed it now, when you choose the scatter file in the T9 TWRP 2840 rar file it automatically chooses the Win Image file. I do have one more queston though please, Is it ok to install the 1.8b custom Rom if the tablet has the earliest stock firmware on it ? Or would it be better to do an OTA update to the latest firmware then install the 1.8b custom rom ? Thank you again
JamesLast edited by Relles; 25 July 2015, 19:50.
There are currently 38048 users online. 1 members and 38047 guests.
