Cube T9 ROM/Tools/Mods, etc
Sorry for my bad english. I have a problem with the phone/3G. Indoor does not hook signal, while outdoors the signal is very strong. With other tablet the signal indoor is good. I think it's a problem with the antenna 3G tablet. What do you think? Can anyone tell me where is this antenna and if you can change it?
Originally posted by devilz-wolit View PostSorry for my bad english. I have a problem with the phone/3G. Indoor does not hook signal, while outdoors the signal is very strong. With other tablet the signal indoor is good. I think it's a problem with the antenna 3G tablet. What do you think? Can anyone tell me where is this antenna and if you can change it?
Here you can see 3G antenna
Originally posted by Edius View PostI don't think is a good ideea to replace antenna. As a last resort you may try to check wire soldering.
Here you can see 3G antenna [ATTACH=CONFIG]n490424[/ATTACH]
I have a question: The black wire soldered to the antenna, comes from the sim card?
Thank you, Edius, for all your instructions and links. I was able to successfully flash TWRP and root with SuperSU. I am a total noob - this is the first time I've tried this on any device. I ran into some problems along the way, since I didn't know what I was doing, so what should have taken a few minutes took me a couple hours trying to look for solutions. I'll be starting a new discussion for noobs, called Cube T9 for Noobs, using the info you posted here, with some additional detail for those, like me who don't know much. Perhaps you can answer basic questions on that thread, so that we can keep this one shorter, and easier to find the info that we need.
Please for your help to me. Soory for my bad english.
I try to load in SPFT this file as a scatter-loading box (MT6752_Android_scatter_6G.txt), but i forget to uncheck all boxes. Than i clicked download and input tablet into pc.
SPFT displayed some warning. Then i clicked help. I read manual and change drop-down list to "format-all and download"
Now my tablet dosen't switch on. Nothing will be displayed. When i pluged charger also nothing.
I try to flash firmware into SPFT, firmware 1.07 (scatter file from zip, and "firmware update" from drop-down list. I have a problem like this.
BROM ERROR: S_FT_DA_NO_RESPONSE (4001)
DA didn't send response data do Flash Tool! (HINT)
Pls help me because my tablet is dead.
Many thanks...
Originally posted by Brunek View PostPlease for your help to me. Soory for my bad english.
Many thanks...
That BROM error is related to some chinese characters on extracted folder names from original FW 1.07 archive.
Extract archive onto your desktop and look after/rename folder with ROM using latin characters.
It was really wrong to use "format all_download"...bad news is you just have a T9 tablet without IMEI..useless for phone calls/3G_4G data. Good news is you can restore your IMEI (I suppose first thing you have done after you received your new T9 was to input your Google account details before that disaster) from your Google Dashboard https://accounts.google.com/ServiceL...com/dashboard/
With tablet in off condition try to flash FW 1.07:
- with default scatter file, all boxes checked in Flash Tool, use this time Format all_Download(worse was done already) and use original USB cable, press Download and connect tablet to PC ...if you still don't see avtivity at the bottom of Flash Tool, disconnect tablet feom USB and press power+volume down for ~ 10 seconds and reconnect to PC (Flash tool must be prepared before with Download button already pressed)
I hope you will revive your T9 using what I said above...for moment I'm at work and wrote all from phone...real painfull.
Tomorrow I'll try to be more accurate.
L.E For IMEI restore look here...all required steps are described properly http://freaktab.com/forum/mtk-based-...106#post423106
You have done an complete backup using TWRP?Last edited by Edius; 22 April 2015, 00:07.
Edius many thanks for your advice and help. Now i have to go to my work but when i will come back to home i will try to reactivate my new tablet (i'm user from only 2 days).
Before that i input my google account and took a photo my phone screen abiut tabket with my imei and another detaiks (if it's help for future).
I will write about progress in reactivate. In touch. Many thanks.
YUPI! Problem solved. Now i have FW 1.07 on my tablet :-) Thank you very very much Edius. Now only will try to restore my IMEI (i have number of this).
I thnik it will be usefull for future.
Many thanks.
[Edit] Now i have one notive in wifi (NVRAM WARNING: Err = 0x10". Before i restored IMEI. Can I good solved this problem? What can i do to reactivated NVRAM file/
Thank you.Last edited by Brunek; 22 April 2015, 20:43.
Here you can see 3G antenna [ATTACH]n490424[/ATTACH]
The black plastic where the antenna is welded inside is empty. It must be so?
In the sticky side (where there are two welds) is there any circuit that acts as antenna?
What else could you do to improve the signal reception 3G?Last edited by devilz-wolit; 26 April 2015, 14:07.
Thanks to hocuspocus69 for posting this link on the main Cube T9 thread. This is supposed to be a way to increase memory partition on the T9. Anyone willing to try this and post instructions in English? http://www.androidiani.com/forum/tut...ml#post6709875
Originally posted by kravmama1 View PostThanks to hocuspocus69 for posting this link on the main Cube T9 thread. This is supposed to be a way to increase memory partition on the T9. Anyone willing to try this and post instructions in English? http://www.androidiani.com/forum/tut...ml#post6709875
This is the procedure to expand the /data partition on T9:
Make aTWRP backup of your T9 (microSD or OTG - not internal SD)
Power off the T9
In SPFT upload Stock Rom with Stock Recovery (The stock recovery is very important. The TWRP not work to do that)
Download the new scatter file, copy the selected scatter file in the folder of stock rom, Open SPFT use the selected scatter and upload in "Firmware Upgrade"
After disconnect the tablet and start it in recovery mode
Make a Wipe/Factory reset (It is very very important to do this)
Restart the T9 and enjoy!
Stock recovery 1.08 full (without chinese apps)
From now on when you use the SPFT will need to do using the new scatter you used now.
Now download the TWRP recovery with spft and new scatter in "Download only"
Restore the backup made at the beginning of the procedure and restart,
that's all
New scatter files (4,6,8 Gb) for data enlargement
https://drive.google.com/file/d/0B0L...ew?usp=sharing
New scatter files wth \System 1,5Gb, \Cache 512Mb, \Data 2,4,6,8,10,12,14,16,18 Gb
This is the new TWRP 2.8.4.0 whit ttf correction & new splash screen
IMPORTANT NOTE:
Repartitioning prevents the OTA update.
Requirements for ota update:
1 - Stock rom
2 - Stock recovery
3 - Stock size of all partitions
thanks to hocuspocus69Last edited by devilz-wolit; 02 July 2015, 12:43.
devilz-wolit, that's great.
I have two questions for you:
1. I suppose you have used V.1.07 with these custom scatter files...OTA update worked right to reach 1.08 FW?
I'm asking because as far as I can remember OTA patches stock recovery too and with TWRP already flashed will lead to failure message.
2.,What is TTE use and TTF correction of TWRP? I think this TTF refers to missing characters error from hanuma TWRP?
Thank's for your kind reply.
Originally posted by Edius View Post[USER="68951"]1. I suppose you have used V.1.07 with these custom scatter files...OTA update worked right to reach 1.08 FW?
RobotoCondensed-Regular : present
RobotoMedium : not present
RobotoRegular : not presentLast edited by devilz-wolit; 27 May 2015, 15:24.
There are currently 3946 users online. 1 members and 3945 guests.
