Cube T9 ROM/Tools/Mods, etc
Yes !! I installed XnetfoX eXtreme 1.6b108with scatter 6Gb. The tablet works perfectly.
For installing the new scatter with 6Gb, I used the stock Rom found in NeedRom with SPFT in "Firmware update" mode. After, Wipe Data factory.
And, i reinstalled Firmware TWRP with SPFT in "download only" mod
finally, in the recovery TWRP, i bakuped the rom XnetfoX eXtreme 1.6b108
hello all
i have install rom XnetfoX eXtreme 1.6b108 and have some problem i can not use gmail it wont get my emails and also some problem with Play store
it says some problem with play store
Do someone have a answer for Gmail App and play store problem
All other work perfect
Regards
OnslowLast edited by onslow2630; 20 June 2015, 16:23.
Delete your google account and re-add account. Some accounts have sincronization problems with playstore 6.6.8 modded. Other solution is replace phonesky.apk in system/priv-app with non modded version.Last edited by devilz-wolit; 20 June 2015, 23:17.
Regards
Onslow
There are currently 2929 users online. 1 members and 2928 guests.
