Cube T9 ROM/Tools/Mods, etc
    Cube T9 Multi Widows Rom
    -ported from Onda V919 4G Air (Mtk 8752)
    I was done this rom , four months ago
    and do not finish as well as it should.
    it only 95% complete
    Hopefully there will be someone who are interested,
    and Proceed to completion.
    Compliment :
    -native multi windows
    -app permission
    BUG :
    -power button's function : incomplete
    -display brightness control : out of order
    Download link:
    https://drive.google.com/open?id=0B4...DBXQWxNMFhOZGM
    Installation :
    -filetype : zip install
    -boot to twrp and select install .
      Originally posted by hocuspocus69 View Post
      Sorry sorry those partition are of my nexus 5 !!!?? What a mistake i'm loosing in a virtual world!!!!
      Someone from 4pda.ru ,do it ready.
      http://freaktab.com/forum/mtk-based-...clast-t98-c6r3
        I read that the T9 has been discontinued. That's a shame.
        Since gaining root access, I have been using the T9 along side the Ipad to see how they compare.
        They have both been running the same custom software for environmental monitoring.
        The data acquisition speeds are about the same, but once the data is on the device the differences are noticeable.
        While running the low level software the T9 has proven to be incredibly fast. Faster than the Ipad.
        The results from running the python scripts are about the same. While the T9 seems to run the scripts faster, it takes longer to load the data from the external SD card.
        While not an Ipad killer, the T9 has proven to be capable and a lot cheaper than an Ipad.
        The one proviso is that users do need write access to the external SD card. This is not a fault of the hardware, just android.
        As an aside, the T9 does a decent job of multi-spectral analysis!
        A big thank you to all the help I have received form this forum and good luck to anyone using a T9.
          HI ctapblu, please help me, give me clear instruction for newbees in order to debrick my T9 ;-(
            Thx helgiman I going to try it ;-)
              HI helgiman
              When I copy preloder given message below:
              Image preloader checksum failed ????
              Thanks for your help plz.
                Originally posted by Casaboy91 View Post
                HI helgiman
                delete checksum.ini from file folder
                  Big Thx, you're the Boss, how can I do now, should I put in SD card 1.07 to boot on it ?
                    or should I flash with other file ?
                      It power on but on chinese ;-( how can applyed flash with no chinese apps now ?
                      big thnaks all for your great support for my issues ;-)
                        and Data service is blocked ?
                          ok no more blocked ;-)
                          how can applied flash with no Chinese apps now ? should I root it ?
                            BIG THX to this great team who help newbees
                            hocuspocus69 &helgiman & mmrrdd & ctapblu & devilz-wolit you're the best, many thanks to save my T9
                            Best wishes to you guys and Happy new year
                              i have similar problem like Casaboy91. I have a Cube T9 and wasn't able to flash it. With the preloader from 4pda.ru mentioned earlier in this thread i was able to flas Firmware 1.08 (also from 4pda.ru). The flashing process works and at the end i can see the green checkmark. But my problem is, that the tablet stays switched off. I can't boot it and the screen stays black. Even Volume Up + Power doesn't work. I can't get into recovery mode.
                              Before i tried to flash the Cube T9 the display worked fine. I don't think that's a hardware problem.
                              Thanks for your help.
                                Originally posted by Milkquarious View Post
                                Press and hold power button for 10 sec.
