Cube T9 ROM/Tools/Mods, etc
Originally posted by hocuspocus69 View PostThis is an original teclast t98 maybe it is better , i never use your app, to share some file of stock ROM or scatter what do you need?Originally posted by hocuspocus69 View PostIs it possibile that i've repartitoning too much my tablet that your suggested app fail something i've 2gb system and 8gb userdata...
I have to make some modifications on this app (rename and block the internet access permission to prevent it from play store's auto update)
please download the new one from playstore, then take and post screen short again
You can get the pressent version here
here ...wrong picture!!!!You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by hocuspocus69; 23 December 2015, 14:47.
Originally posted by helgiman View PostI am trying to port lollipop from P98, and its load, but touch is not working.
Lollipop from P98 to T9 ?
load but touch is not working ?
I could not get past the continuous bootloop!
You want to share your porting?
Who knows, you might find together a way to make it work!
HI!
I stopped working on lolipop P98.
I think everything depends on the kernel. If you flash P98 firmware with T9 preloader, it will boot, but touch does not work, and the screen will be rotated on 180. I tried to change the libs, kernel, etc. according to instructions from xda. But it is bootig with only P98 boot.img, ie, native kernel, with not working touch and rotated screen. I tried to connect a mouse, but OTG does not work either.
Need any other donor or source code for the kernel.
Inviato dal mio T9 utilizzando Tapatalk
There are currently 2805 users online. 0 members and 2805 guests.
