Cube T9 ROM/Tools/Mods, etc
I read in saransaro : Simple step to get rid of BROM ERROR S_FT_ENABLE_DRAM_FAIL (4032) is just ensure that the files which you are trying to flash are exact version of your mobile phone. If it is so, try formatting your phone. Make sure that don’t format the boot-loader before flashing it. You can try downloading preloader and move it to target_bin folder and rename or move checksum.ini from target_bin.
But I don't how to applied it
Thx for your support ;-)
Originally posted by Casaboy91 View Postany idea ?
Your problem has already been solved. Description is on 4pda.
On tablet with the serial number of the form: T9GT32GB154XXXXXXXX the manufacturer has applied a different file preloader. Therefore, the firmware turns brick. We were able to overcome this problem, and all the victims regained and is now happy because the tablet. Instructions and files needed for recovery can be viewed and downloaded here: link
There are currently 2809 users online. 1 members and 2808 guests.
