Nexbook AMlogic root WORK!
Originally posted by Finless View PostNextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
AML8726-M3 Cortex A9 @ 1GHz
Nextbook Premium 8 HD (N0008HD8G) - * ROOTED *
Nextbook 8 (NX785QC8G) - STOCK (unfortunately)
NEXT7P12 amlogic root
Hi, Everyone, Any idea how to root a nextbook 7p12 with seq YF1012* on an amlogic? Though the filesystem looks to be yaffs not ext3. Below are some info dumps:
shell@android:/ $ cat /proc/mtd
cat /proc/mtd
dev: size erasesize name
mtd0: 00400000 00100000 "bootloader"
mtd1: 00800000 00200000 "logo"
mtd2: 00800000 00200000 "aml_logo"
mtd3: 00800000 00200000 "recovery"
mtd4: 00800000 00200000 "boot"
mtd5: 20000000 00200000 "system"
mtd6: 08000000 00200000 "cache"
mtd7: 20000000 00200000 "userdata"
mtd8: b5400000 00200000 "NFTL_Part"
127|shell@android:/ $ mount
mount
rootfs / rootfs rw 0 0
tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600,ptmxmode=000 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
ubi0_0 /system ubifs rw,relatime 0 0
ubi1_0 /data ubifs rw,nosuid,nodev,relatime 0 0
/dev/block/mtdblock6 /cache yaffs2 rw,nosuid,nodev,relatime 0 0
none /proc/bus/usb usbfs rw,relatime 0 0
/dev/block/vold/250:33 /mnt/sdcard vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,g id=1015,fmask=0002,dmask=0002,allow_utime=0020,cod epage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/250:33 /mnt/secure/asec vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,g id=1015,fmask=0002,dmask=0002,allow_utime=0020,cod epage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
tmpfs /mnt/sdcard/.android_secure tmpfs ro,relatime,size=0k,mode=000 0 0
127|shell@android:/ $ cat /proc/cpuinfo
cat /proc/cpuinfo
Processor : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 1556.48
Features : swp half thumb fastmult vfp edsp neon vfpv3
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x2
CPU part : 0xc09
CPU revision : 4
Hardware : AMLOGIC MESON3 8726M SKT SH
Revision : 0020
Serial : 000000000000000c
Hi, Finless, Greetings to you and thanks to your great work! Also thanks to everyone on the thread for sharing the information.
Originally posted by eegorr View PostLooks like I am BRICKED!! Charge LED doesn't even come on, either from USB or AC adapter.
Please explain exactly what happened step by step and where it bricked. It should not have bricked.
Also to unbrick removed SDcard and hold power button for like 15 seconds which should ofrce power off. Then try power on again.
This did not replace uboot so it should not have bricked.
ozymandiaz, this procedure will not work from intrnal sdcard! It will only work from an external sdcard.
Originally posted by eegorr View PostLooks like I am BRICKED!! Charge LED doesn't even come on, either from USB or AC adapter.Nextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Ramos, please start a new post for your question since we are working on something else here.
Originally posted by ozymandiaz View PostDamn, it didn't even start the install for me. Did you copy it over to internal /sdcard directory or a microSD when you tried? A week or two ago I was in a similar mode where I thought it was bricked but I was able to get back into stock recovery and do a factory reset and it was fine after that... Hopefully that's the case with yours.
Eegor, I need to know what your got step by step please. What happened etc.
Then I powered off, pressed vol - and power. It did nothing at all, and when I connected it to USB there was no charge LED! Tried on AC adapter and still no LED.
I pressed reset for 15 seconds using a safety pin and now I am back. No external card inserted yet.
EDIT: Popped in the uSD card and the tab became unresponsive again. Will it try to apply the update as soon as the card is mounted? That's what appears to be happening.Nextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Originally posted by eegorr View PostI put it the files on a new external uSD card (not SDHC - 512MB), reformatted via settings first.
Try again.
Originally posted by Finless View PostSomehting went wrong with your setup. The fact that ozymandiaz got my recovery to boot shows some other problem with you. Try formatting sdcard using a PC not the tablet. Copy the files to SDcard using a PC to make sure no corruption.
Try again.
BobNextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Originally posted by eegorr View PostI'm trying that now. Formatting the uSD card in my PC, should I use FAT32?
Originally posted by Finless View PostYes fat32
Tried power and vol- buttons and it is unresponsive again.
Reset and tab is booting.
I'm going to try again with another uSD card - 2GB FAT32.
EDIT: No joy with brand-new 2GB FAT formatted (that is how it came). The tab does exactly the same thing. I'll go ahead and reformat FAT32 and try again, but it doesn't look good.
BTW, I can run the upgrade app as well and it sees your update_root_ext3.zip file. When I reboot the tab to install the update, it hangs in exactly the same way! I haven't tried putting it in the internal SDCARD directory, though.
EDIT2: Still no good.
1) Formatted 2GB uSD card FAT32 on PC
2) copied four files to the uSD card via PC: aml_autoscript, uImage, uImage_cwm, update_root_ext3.zip
3) With power off, inserted uSD card into slot of tablet
4) Hold vol- and power buttons... nothing happens, tablet is hung until I reset it.Last edited by eegorr; 15 December 2012, 23:16.Nextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Hmmmm try removing the file uImage from the sdcard. Leave uImage_cwm
See what that does.
Originally posted by Finless View PostAlso to unbrick remove SDcard and hold power button for like 15 seconds which should ofrce power off. Then try power on again.Nextbook Premium 8 SE (Next8P12) - * ROOTED * (Sold on ****)
Meanwhile I'm in spectator mode... Tore apart an entire house worth of gadgets and I don't have a single microSD card... All of my other phones / tablets are Nexus brand sans microSD slot. I'm digging around looking for an old MP3 player that I know has a 2gig card in it but am drawing a blank. It might be in my wife's car but she's out and about at the moment.
There are currently 6810 users online. 0 members and 6810 guests.
