MK808 - Finless 1.6 Custom ROM
OK to answer a few questions here:
lukewarms:
Your issues sounds exactly like you have the Sunvel MK808B clone. Especially the issue with powering only by the OTG port. Original MK808 does not have this problem! I suggest you try my new Sunvel Clone ROM. I bet you do have a MK808B Sunvel.
Head_shot. There is a mistake in my instructions. USB should be turned ON not off.!!! USB debugging should be off.
Jogg3r, this will not work on a All Winner system. Dont even try or you will brick.
stedmakr, no rockchip devices do 5.1 yet. We are hoping rockchip fixes this soon!
Originally posted by Jogg3r View PostHm. Okay, thank you for you quick answer.
you dont know another rom , dont you?
You might ask FreakTab developer Electrik if he is willing to try. He know All Winner better than I do.
Trouble Flashing ROM
Originally posted by head_shot View PostNewb here.
I'm been working on this for about a day now, and I just can't get the "Finless ROM Flash Tool" to find the device. I've installed the drivers, and it shows up under Device Manager. But when I start the Finless ROM Flash Tool it continues to say "No Found RKAndroid rock usb."
I'm at the part of the instructions where it says this:
"4) YOu should see at the bottom it says "Found RKAndroid Mass Storage USB"
If it does not say that go into settings and make sure that
a) USB storage is turned off
b) Under developer options, USB debugging is turned off"
Where are these "settings" located?
Thanks for any help you can offer. And thanks for giving your time to this project; I'm excited to give it a try!
Am I missing something? Sorry for being such a newb.
Originally posted by head_shot View PostOkay, I've hooked the MK808 up to my HMDI connection on my monitor, have a mouse connected to the MK808, have a USB cable in the OTG port of the MK808 (ready to plug into laptop PC), I have a straightened paperclip, and am pushing on the reset button WHILE I insert the OTG USB into the PC. The PC recognizes the device and loads the x64 driver. I release the paperclip. Nothing happens on the HDMI monitor. I launch Finless ROM Flash Tool and it still says "No Found RKAndroid rock usb."
Connect to TV or monitor, then check this is OFF
Then remove from TV and connect to computer and flash.
Make sure the USB cable connects to the REAR USB ports NOT front or a hub.
Of course I am a newbie here but I flashed mine just fine
Originally posted by Finless View PostOK to answer a few questions here:
lukewarms:
BobLove your work, thank you!
Beware of **** purchases for this people!
Thanks Kyle...
Originally posted by KyleK29 View PostYou can flash 2Dark4U's kernels onto the 1.6 base. It doesn't need to be included in a 1.7. I think Alex is still testing an ocing kernel (not yet released, last I check).
Just open up the 1.6 ROM flash tool and replace the "kernel" area with the one you get from 2dark4u's website (there's a thread here with a link).
SO could you lease add the link you were referring to and a teenie bit more info on what "replace the "kernel" area with the one.." really means, a.k.a. action for me to take. Thanks for your time regardless- B
Originally posted by High_Yield View PostI'm Ok with doing things when they are already "fully packaged", like the base 1.6 upgrade, but when I vary from the path, I may get bricked (kinda funny eh?).
Logitech H800 Headset works!
Originally posted by japasco View PostGreat job on this ROM Bob, it saved me with my MK806.
Will wait for your new releases as I'm following you now :thumbup:
Cheers,
Jorge
Enviado desde mi GT-I9300 usando Tapatalk 2
Also my Logitech mouse (M305) works.
Everything was connected to a external powered Targus USB hub.
Thanks again.
Jorge
Hi Bob,
I just bought a MK808 from AliExpress, but the Blue LED is not ON and no display when turn on the power supply. Had changed the power supply but still the same. Is it a faulty MK808 or custom firmware problem ? Need your advise. Currently , also waiting for the reply from the supplier.
There are currently 2009 users online. 0 members and 2009 guests.
