MK808 - Finless 1.6 Custom ROM
Hi all,
I flashed this ROM successfully last night without errors but when I plugged it into my TV i get nothing. I have an older 1280x720 TV which worked with the stock ROM. Its difficult to rule out if it is just a display problem because obviously I cannot soft power down the device without a display, therefore every time I try it on a TV I have to reflash it - in fear I have bricked it by pulling the power out.. I am using the standard HDMI adaptor cable that comes in the box.
Also, the blue LED turns on for about a second when I first apply power but then goes out.. is that normal?
Thanks!
Luke
Re: NEW - MK808 - Finless 1.6 Custom ROM
Thanks!
Luke
I'm not the lowest of the low, but I am the slowest of the slow (49.6 mpg over 38k miles in Scion xB)MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
Link for download is fixed.
I can't seem to connect 2 USB devices at the same time. I have a Mele air mouse connected to the USB port and if I connect a Logitech game pad to the OTG port it crashes after a few minutes. I ordered a powered USB hub and a 2a power adapter. Hope it will fix that. Anybody else having a similar issue?
Envoyé depuis mon GT-I9100 avec Tapatalk
Originally posted by dancar View PostI don't have easy access to windows system. Does someone have instructions how to flash using an ubuntu system?
Thanks,
Daniel
Display problem solved
Originally posted by exglynco View PostDid you erase NAND before flashing? The blue LED should remain on when the device is powered.
OK, i have an update with my display problem. I noticed the bule LED stays on when I power it via the USB cable in the OTG port.. and lo and behold theres display! So nothing in the power port - just the OTG.
My problem now is the Wifi and bluetooth cannot turn on - when i switch the wifi on it turns itself off after a couple of seconds. The Bluetooth switch doesnt stay on..
Originally posted by lukewarms View PostOK, i have an update with my display problem. I noticed the bule LED stays on when I power it via the USB cable in the OTG port.. and lo and behold theres display! So nothing in the power port - just the OTG.
hey guys, first: Great Job, the finless rom works great on my mk808! And the shutdown button, just awesome. My question is, i have another android pc the mk809 with a10 allwinner main chip. can i run this rom on this stick, too? Because this second stick is very laggy while playing online movies..
maybe another rom could help?!
here are a few details:
android 4.1
Allwinner A10/1,6 GHz
Memory: 1 gb
graphical processer: 2d/3d/opengl es2.0(amdz430)/open vg1.1 (amd z160) <- ?
thank you =) hope for answers
Trouble Flashing ROM
Newb here.
I'm been working on this for about a day now, and I just can't get the "Finless ROM Flash Tool" to find the device. I've installed the drivers, and it shows up under Device Manager. But when I start the Finless ROM Flash Tool it continues to say "No Found RKAndroid rock usb."
I'm at the part of the instructions where it says this:
"4) YOu should see at the bottom it says "Found RKAndroid Mass Storage USB"
If it does not say that go into settings and make sure that
a) USB storage is turned off
b) Under developer options, USB debugging is turned off"
Where are these "settings" located?
Thanks for any help you can offer. And thanks for giving your time to this project; I'm excited to give it a try!
There are currently 3584 users online. 0 members and 3584 guests.
