Sent from my MK808 using Tapatalk HD
MK808 - Finless 1.6 Custom ROM
Re: NEW - MK808 - Finless 1.6 Custom ROM
Originally posted by Mopheus View Post1) To make file transfer easy I use: ES File Explorer, and you need to enable Root access to be able to put some files inside system (you need to be able to write there).
2) From this topic: http://forum.xda-developers.com/show....php?t=1792531 (you need the uncompressed files)
Get:
http://forum.xda-developers.com/atta...4&d=1343146324
3) Copy the uncompressed files u downloaded here: /system/usr/keylayout/
4) Make a copy of this file and rename it like it says:
Make a NEW Copy this one: Vendor_045e_Product_0291.kl
And Rename to: Vendor_045e_Product_0719.kl
5) At this point u should have 3 new files on the /system/usr/keylayout/ directory:Vendor_045e_Product_0291.kl
Vendor_045e_Product_0719.kcm
6) Just change write permissions using ES File Explorer on those 3 files to ensure they have:
RW for USER or OWNER
R for OTHERS
7) Reboot and u'r done.
Dead Trigger works with the analog pad's but you need to define shot and reload buttons at least, unfortunatelly (not sure why) you can only use the triggers, cause it's not recognizing any buttons yet, but you can play perfectly.
Hope this helps... anyway, the linked guide is almost the same , I just made it easy (I think)....
Originally posted by Okan View PostHi everybody,
I have just installed 1.6 on my MK808 but I cannot get wifi work. I go to setting and check the box to turn on the wifi, it says "turning wifi on" but then it unchecks the box and disables it.
Any ideas how to solve this? Thanks..
Please... BEFORE YOU FLASH ANY ROM.... Know what you have.
I honestly am suprised that anyone would try to flash a ROM..... NOT KNOWING.... if a stock ROM exists for them to recover to!
OK.... never mind
Originally posted by Maxtone View Postthx
How can install only the kernel?
Bob -- I hear ya man - but I will be completely honest I am pretty reckless with this device compared to my phones and tablets. Between the low cost and how fast the tech is evolving with these tv sticks I really don't care that much if I brick it, which for me is wearing out the flash from crack-flashing it. Hell I already have a gk802 I plan on upgrading to sitting a static bag until we can figure out how to get the video to work. I say we (as in community) because I haven't made much progress on my own
Sent from my MK808 using Tapatalk 2
root not working
I read this whole thread and searched as well as I could - so I hope this isn't a dumb question. I found one other person complain about the same problem, but there were no replies.
I flashed finless rom 1.6, no errors, went great, up and running, BUT I don't have root access -
any app that asks for it gets denied.
superuser says the binary is installed to root/system/bin/su .... other apps seem to ask for /system/bin/su
i tried titanium backup, busybox, rootchecker ... they all said they didn't get root access.
what could i have done wrong, and is there a way to root now that I'm flashed? ( linux user, although I can get a vista box if i have to ... )
thanks in advance -
Originally posted by slcpunk View PostI read this whole thread and searched as well as I could - so I hope this isn't a dumb question. I found one other person complain about the same problem, but there were no replies.
thanks in advance -
There are currently 2065 users online. 0 members and 2065 guests.
