thanks for your help!
MK808 - Finless 1.6 Custom ROM
Guest
Any possibilities of fixing BT on this devices ? It's the only thing I really need and can't get to work... it's really strange considering I've got older devices witch could handle BT easily, but on this baby, no luck yet with any of my dongles.
Thanks !
what is the new 2dar4u kernel that i should install with this rom? 720p or 1080p?
if i install 1080p it will work on a tv/monitor that is not 1080p? (i've tv 1080p but also a monitor that is not) or is better to install 720p so that it will work for sure on both tv and monitor?Last edited by krukko; 05 February 2013, 01:16.
Originally posted by Maxtone View Postdo you recommend a good adapter for the power..
I'm not saying all are bad, but with my history of buying chinese adapters and batteries, I rarely can trust what they claim.
Originally posted by krukko View Postwhat is the new 2dar4u kernel that i should install with this rom? 720p or 1080p?
Originally posted by KyleK29 View PostAnyone have a mirror for Finless 1.5a? I need to go back for it to work with my garage TV.
Here is the post for the MK808 1.5a and the downlod link still works.
Can I ask why you need this? It is freakin old and full of bugs compared to 1.6 so I would like to know why you want to go back to this?
Originally posted by n00b View Posti used the original 2ampere power adapter, isnt this sufficient?
So I want to roll-back to 1.5a and see if it is something in the ROM that changed.
Cifs.ko finless 1.6 rom
Hi All
I came across finless 1.6 rom the other day when trying to get cifsmanager working.
I was getting error “no such device or address” which I found was because I didn’t have cifs.ko loaded.
Having no idea how to inject cifs.ko working I came across finless 1.6, which had cifs.ko module add in release notes. Great
I installed the rom and so far I am loving it but I am still unable to mount my NAS with cifsmanager.
I am getting the same error and when I checked cifs.ko was not loaded and I could not find the file although TUN and MD4 ko files were there.
I had no errors when I installed the rom.
Do I need to reflash it or is the file hidden.
Help would be much appreciated.
Originally posted by KyleK29 View PostMy bad, didn't even realize there was a 1.5 post still. I have a Westinghouse LVM-37w3 in the garage (which is what I use the MK808 for). Since I've gone to the newest ROM's (tried 1.6 and CM10), it won't display on that TV. Just a black screen. Displays on my other TV's. Tried various settings. 1.5a worked fine.
There are currently 1887 users online. 0 members and 1887 guests.
