was originally using kastys firmware tried morkas, yours is the best yet keep up the good work.
Arnova 10 G2 Custom ROM with Market3.4.4 by Finless Version 1.4
Absolutely fantastic ROM. Flashing process was simple and easy... Tablet now runs much faster with this.
Thank you sooo much! I finally feel i have a useable tablet as opposed to some bloated...
Having the issues with the google market as described in the OP however- Working on it now.
EDIT: Market issues seem to have been resolved. I followed the instructions in the OP, but i still had the really limited apps, however i did notice that after closing the market and going away doing other stuff, it had updated to the new google play store, asked me to accept the terms and conditions etc, then gave my access to all the apps
Hope this helps someone else that is having the same issue.
-eKKoLast edited by eKKo; 09 March 2012, 13:26.
Originally posted by bigstevie View PostBy any chance do you know the launcher for morkas firmware so many on the market not sure,
thanks if u can help outPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Actually Morkas launcher is a installable one. It's called Launcher2.0 or something like that.
I forget who makes it now but it is on the Market.
another thank you
Finless
Just wanted to add my thanks and kudos to you for what you do, karma will truly smile upon you. this is my first play with android, dont want an apple slab and to be honest wasnt overly impressed with the usable but not great factory OS. what a difference your install makes.
thank you
You guys are all welcome! Glad to hear your all having good success
Thanks for this great rom
You can try to just flash boot.img and system.img only and it should save all your apps and stuff.
Originally posted by Finless View PostYou can try to just flash boot.img and system.img only and it should save all your apps and stuff.
thanks bob
I have never flashed before , and was nervous as i have only just got the 10 g2 , but the instructions were great , and it was easy. . I had a slight problem with play store ( old market ) showing some apps but nothing in the free screens.But after loading es file manager , and following your tips to show hidden files and to move the home directory to / ( i would have been lost without that help) then deleting the files you mention it eventually worked . As a note i had to do it twice because it did not work 1st time, but between doing it a 2nd time i deleted the cache from play store ..then it worked ..all apps to see.
Brilliant Bob, and thanks to all who have helped in this. I will recommend this to others
Originally posted by carlospaco View PostHy Bob, I have flashd the whole rom, works great, but still i have know 3g. My dongle is a huawei e173, i really need this. But the rest off the rom is excellent.Thanks for this.Is there somebody with the same dongle?
Bob resolved my problem with custom boot.img and system.img.
if Bob agrees, I can send them to you.
Bob, can I send the 1.4 ROM 3G Tests with sended to me?
There are currently 1488 users online. 0 members and 1488 guests.
