Arnova 10 G2 Custom ROM with Market3.4.4 by Finless Version 1.4
Thanks for the rom 1.4! Perfect!
Bob, what do you think about ICS on Arnova 10 G2? ICS for Archos 80/101 G9 OS v4.0.4 is ready: http://www.archos.com/support/suppor...try=gb&lang=enArnova 10 G2 & finless' 2.2b PRO
Originally posted by Finless View PostArnova 10G2 Kernel build date: Jul 14 2011
Anorva 10G2 Philly kernel build date: Dec 20 2011
So folks... we have a new kernel in the philly tab and there are LOTS of changes in it.
FYI the new kernel appears to support yaffs too! Interesting... Yaffs is a compressed file system like cramfs but it RW and it is made to perform better in NAND memory.
Something to look into.
Bottom line I will be cooking all new 10G2 ROMs based on these updates.
* do you think it would be worth switching to yaffs (compared to ext4fs).
* And if yes, do you think it will be difficult to adapt what you already did about ext4?
* last question : how is the work about a clockmodwork like tool going?
thanks again for improving our tablets. I really appreciate your work.
I cant say it is normal or not. I have not used 3G stick yet.
But you have to consider that the USB port is powering the 3G stick so it is expected it may run hotter.
How do I restore the original firmware?
I have been using the Finless 1.4 since Bob launched it and it's great. Unfortunately my tablet has developed some issues with the touch screen and it will need to go back to Arnova. Before I do that I need to restore the original firmware. I have the update.img file but what do I do with it? Copying it to the root and rebooting didn't work. I'd really appreciate some help with this.
You have to flash the update.img with the RKBtach tool!
See this post on download for that tool and instructions. Even though it is for the nextbook, the instructions and tool is the same for all rk29 tablets. Since you already have the drivers installed in wondows you do not need to do that again. Just run the RKBatch tool and flash the update.img you have using it:
Hi Bob,
Thanks for the fast reply and the info. I really appreciate the help you give us noobs!
So my G2 is now back to being its brain-dead original self! Hopefully I can get a new one and get your ROM on it ASAP!
Best regards...
Scrofula
Originally posted by Finless View PostYou have to flash the update.img with the RKBtach tool!
There are currently 2524 users online. 5 members and 2519 guests.
