MK808B clones, how to identify them.
Re: MK808B clones, how to identify them.
Originally posted by exenew View PostI bought this called "tronsmart" from Amazon - is it cloned?
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Rk901seems a mk808 original.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by exenew View PostThanks, so I should be ok with looking into firmware that says for original mk808, right? Or there is still more to it...REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by exenew View Posthey leolas...i just realized that compared to other mk808's (nonB) i only have one antenna - is that normal or am i missing something?
Identify MK808b without opening up
Hi Guys,
I think there is another way to find out if your mk808b is original or clone.
1.install terminal emulator from playstore and open it
2.type su (you must be rooted)
3. type dmesg
From the output scroll down and look for the wifi entries and see if it is rk903 or something else
There are many entries so keep looking to end of the output.
I cannot confirm if this is the conclusive way because i cannot test it as i do not own a clone mk808b.
Those clone owners can you test it and feedback.
3. type dmesg
Originally posted by leolas View PostYou are right, in this way you can check if the mk808b is the "original". Can't difference the clones. And allways if you are in your stock rom. If you installed a custom before this way don't work
leolas
OK, i get it.
Read somewhere the wifi mac id can help. is that correct?
Help help help...
I am desperatly seeking for solution... I flashed my Mk808B after it wouldn't start. Sadly I didn't do any backup. Now after trying every firmware I can find, it starts but it is impossible to get the wifi and bluetooth running.
From the pictures I've seen there is no one that looks really like mine.
It has only one antenna and no heatsink.
The wifi-chip is Mediatek MT5931 and the Bluetooth-chip is Mediatek MT6622, so from what I read I should flash it with the Sunvell clone #1 firmware. But with no success.
([VonDroid.com]-[VonDroid.com]-ROM STOCK MK808B CLONE #1.zip)
I´ve also tried the clone #2 firmware, the original firmware, finless all firmwares and the cusom firmwares.
The only one I havn't try yet is the most recent ones from this week, but they shouldn't work due to the Mediatek chips...
Anyone have an idea???
Thankful for replies.
/Stefan
There are currently 2018 users online. 1 members and 2017 guests.
