MK808B clones, how to identify them.
Originally posted by San0k View Post
Originally posted by rdsok View PostThe only way to tell which fake you have is by opening it up and looking at the chipsets on both sides of the device... If you can't identify it by comparing it to the ones already listed in this thread... post pics of both sides of the electronics and maybe someone can help you... without the pics, you can't get any real help, just blind guesswork
I have same device:
Originally posted by ygolonak View Post[ATTACH=CONFIG]4848[/ATTACH][ATTACH=CONFIG]4849[/ATTACH]
this is my device, could someone please tell me which rom works, I'm desperate, thanks
Green PCB, RK3066, AP6210 radio-chipset and single-antenna.
Originally posted by San0k View PostI have same device:
Green PCB, RK3066, AP6210 radio-chipset and single-antenna.Originally posted by San0k View PostOnly rk3066_T005_Launcher2_public_20130121 firmware provides to start my MK808B. But without wifi&bt
Here is one from w2comp that uses that chipset... it working on mine ( mine has a blue board instead ) but can't say for certain it will on yours... http://blog.w2comp.com/2013/12/15-de...-firmware.html
PS... if the link doesn't take you to the proper download... look at the 15 Dec 2013 blog for the MK802 IIIS ...
The above link is the same one I posted about on post #161. There is another one that I posted about on #151 that is an earlier version and others have posted some after that as well... perhaps one of them may help
MK808B firmware backup
Here is my green pcb 1 antena mk808b, bought from pandawill, android tv box :
runs android 4.2.2 (rk30sdk-eng 4.2.2 JDQ39 eng.zs.20131219.191736 test-keys) RK3066_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130308 ; it has ap6210 chip onboard (wi-fi and bluetooth).
The main problem with that device is low performance in playing hd and full hd fideo on 23' monitor. I assume that is because of locked to 1000 MHz cpu frequency. When playing hd movies it consumes almost 100% of cpu. And the picture is not smooth (my eye can catch those frame drops though xbmc shows 30-40 fps) - tried different players - same result.
By the way stock rom doesn't do full hd though it has 1080p but it seems to be 720p comparing to same monitor attached to Windows laptop.
I would apriciate any help to unlock cpu of mk808b or tell how to do it and if it would be efficient.
There you can download backup.img from it : https://www.dropbox.com/s/y5ztuupdi2hzeg0/backup.img
You can use https://www.dropbox.com/s/pw3j12v5tz...ckerRK_103.zip to upack those img files from backup.
Worked!
Originally posted by griser View PostHere is my green pcb 1 antena mk808b, bought from pandawill, android tv box :
runs android 4.2.2 (rk30sdk-eng 4.2.2 JDQ39 eng.zs.20131219.191736 test-keys) RK3066_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130308 ; it has ap6210 chip onboard (wi-fi and bluetooth)...
I did it this way...
Originally posted by hothmonster View PostHi,
Anyone have any instructions on how to apply the above?!
Then I've put them in a folder together and using drag and drop of the backup.img on the executable imgRePackerRK.exe the .img archive will be extracted.
You then get a folder named: backup.img.dump
In this folder you will find all .img files you need for the flashing.
Then using ROM_Flash_Tool_137.exe you can flash them on your TV Stick by selecting each .img file in the appropriate field, or by pasting in an existing Finless package and renaming each .img file and RK30xxLoader(L)_V2.07_lock.bin file appropriately.
I used the Finless package MK808b-ap6210-Finless-2.1-ROM.zip
Good luck!
There are currently 3257 users online. 0 members and 3257 guests.
