MK808B clones, how to identify them.
    Help an old almost blind man
    Here are the info from setting
    android v 4.1.1
    kernel v 3.0.8+
    ifwang_v_300j#16
    smp preempt sat Nov 10 09:46:48 cst 2012
    build mk 808_300j_10-11-2012
    on the outer cover mini tv for android
    dual core A9 processor
    inside info after openning
    RK901
    TOC 9002
    1237
    now what?is it original or a clone and what rom goes on it?
    it is an old piece,does it have a stock rom on this site?
    here are the picture,your input is appreciated
      android v 4.1.1
      kernel v 3.0.8+
      ifwang_v_300j#16
      RK901
      TOC 9002
      1237
      That is a original MK808 (non B). Prahjister Rom should work. MK808 Finless Roms should work too (if you can find a working Link). The latest MK808B Stock rom should also work.
        If you need wifi....i found out recently that the wifi performance is bad for 901 wifi.
        Here is a link based off of latest stock for the non b with all the patches applied.
        If you have the ability to use a usb ethernet adapter i would suggest using prah v5 1.1. It is smokn fast.
          Originally posted by spinx View Post
          This stunds great! I will try to make a full backup /dump of the Rom tomorrow and post it here. I will follow finless guide. Thanks in advance!
          I believe i have managed to dump all necessary files here, please let me know if its not correct. I would also like to have 1080, overclocking, max performance etc like Finless rom's
          UPDATE! I belive i did my homework
          After countless hours of testing, i have med some great progress. My conclusion after indetifying the Wifi/BT chips was that its likely a UG007/-2 clone of some sort. Therefore i searched for all UG007 ROM's i could find and tried them all. Tested about 8-9 roms with various results and finally i belive i found the perfect one.
          Kitkat 4.4.2 from here and filename rk30_dongle_mtk_4.4_140617.img
          Flashedwith RKBatchTool and booted successfully with Wifi & BT! Even flashed a OC kernel with 1608-400-533 clocks using RKAndroidTool. So faar so good
          Any idea of a wifi-tweak for me? Im pretty happy with the performance except on wifi.
            Originally posted by Akure View Post
            Bricked flasing rom, have green status light in batchtools it goes into recovery without need to push reset buttonwhen plugged into otg, every rom faills to flash , I need to get it into MASK ROM mode to flash Nand chip, model Skhynix unsure if I short PIN 8 and 9 or shortpin 9 and 10 unable too find any info on this board. I have another stick same model only images work are T011 images. Unabe to obtain original stock image from seller. Anyone with stock image or any images for this model? also any help in putting this device into mask mode or flashing SD METHOD.
            PLEASE TALL WHAT YOU DRIVE CLONE OR ORIGNAL I HAVE THISE ITEM I CAN'T identify them. PLEASE TELL IT CLONE OR ORIGIAN CAN EMAIL [email protected]
              JB ROM?
              Originally posted by katchet View Post
              Hi buddies
              Mine is like srysry one but without heatsink, bought xpress.
              There is "HTC-T011-V4 2014-02-18" writing on the board and wif/bt chip seems to be "Realtek 8723Bs".
              I have erase nand in trying to set linux. Nothing worked after that, only few old firmwares but without wifi.
              Great thank to srysry, with his linked firmware my mk808b is back.
              It is a good box, better that previous instable mk802.
              As use this old one as web, mail server and print servers, some times with Atrix laptop.
              Now, I will continue to try setting linux on my mk808b.
              It seems as hard as finding the stock firmware.
              I look for tracks to use Linux on it...
              See photos of my Mk808b and thank you again srysry for this link.
              Anybody find a JB rom for this one?
              Also, can anybody point me in the right direction to a reliable seller for the original MK808B or even the V5........
                I don't think that there is a JB rom for this one. But what's the advantage of JB?
                The original mk808b is not produced anymore. You can get the v5 from geekbuying, but there is really no point in buying a mk808b anymore. The mk808b plus is cheaper and more powerfull, you should get one of those.
                  android stick mk808a need firmware
                  I need help. I bought on ****. I tried to root. wifi is not working. I tried 5 firmware but doesnt wifi and bluetooth. mk808a written on mainboard. I have 2 stick and the other work. from the menu the other about writing device model number rk30sdk. help
                    I have probably the same stick - I tried also more images and I found working (at least WiFi) with either Finless iMito image 2.0 (rooted):
                    or KitKat:
                    or this RKM (rooted, but you have to install SuperSU from GP)
                    For me the best seems to be RKM, but with all of them I got WiFi only, no bluetooth.
                    If you'll try it, let me know if it works for you.
                    Good luck
                    Tomas
                      yessss
                      yes it works now with iMito rom. thank you very much thomas
                        It's my pleasure, nice to hear, that it works for you.
                        What's about bluetooth, works too, or just WiFi?
                        Tomas
                          Tomas
                          just wifi not bluetooth
                            I have the same one I think. Yours also have 2.5 gb nand flash instead of 8gb?
                              How about usb-lan, also works fine?
                                Yes, only 2.5GB free - so the internal Flash is 4GB instead of 8GB. I wanted to ask the same.
                                Seems we were cheated
                                Tomas
