MK808B clones, how to identify them.
thanks mate. your upload fixed my bricked device. yeah i get terrible laggy performance on xbmc even on standard def stuff.. no builds of xbmc (lastest nightly, XAF or standard) makes any difference to the choppyness... thats why i bowled in and started flashing incompatible roms in the first place...
i tried flashing finless ap6210rom - system.img - seperately, it boots but no joy getting wireless to work even with a external wireless dongle..
i dual boot linux mint and no stranger to the terminal, if i had a decent guide i'd give adding the wireless drivers to the rom a shot but to be honest i'm just an advanced noob with no idea...
so heres hopeful to clever devs making this piece of s*** decent enough to play hd vids
Originally posted by crazyflasher View Postno builds of xbmc (lastest nightly, XAF or standard) makes any difference to the choppyness
Originally posted by Bueno View PostYou didn't try the one that works the best: http://www.freaktab.com/showthread.p...BMC-(Beta-3-3)
This one hardly runs anything..Can only get the default OS to load. None of the other custom roms work.
does anybody know this one???
Hi everybody!
i´m desesperated, i can´t find which is the firmware that could do work my mk808b clon. I have tried a lot of them, buy anyone is the correct. It has mediatek 5931sa and mt6622n. The blue light turn on, but the tv shows the "no signal" message. I insert a couple of images. Thanks a lot for your help!!!
Good news
Good news for owners of green pcb 1 antena mk808b android 4.2.2 (rk30sdk-eng 4.2.2 JDQ39 eng.zs.20131219.191736 test-keys) RK3066_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130308 ap6210 chip onboard owners! The ones who successfuly recovered the stick from my backup.img
If you haven't yet threw those piece of .. to rubbish bin as I intended to do, a little later I will post all data to get it working under Finless 2.1 with wi-fi and bluetooth active, playing video smoothly!
Moreover there will be overclocked versions of kernels runing cpu on 1608 and ram on 533, both for 720 and 1080 resolutions!
I will provide all necessary data with detailed instructions. It's will take some time.
Hi Terencio or phinc,
I think mine is the same as Terencio's. But post #43 contains no link.
Which ROM worked for you Terencio? (Edit: The answer is this original ROM, thanks phinc)
griser, is mine the same as yours? If so I'm so looking forward to your ROM!Last edited by aximili; 05 April 2014, 09:02.
There are currently 2226 users online. 0 members and 2226 guests.
