MK808B clones, how to identify them.
i got same model as you
Originally posted by Sikriffs View PostAnybody find a JB rom for this one?
Also, can anybody point me in the right direction to a reliable seller for the original MK808B or even the V5........
do you know where can find rom that can suit this model
I supposedly got MK808B but looks weird ...
WIFI, BT and 1080p works good in "stock" soft
I opened the box (looks like real MK808B) there is factory radiator + MT6622N chipset and MediaTek MT5931SA, and TOSHIBA memory
Other information from SETTINGS
In information: rk30sdk
Android 4.2.2
kernel 3.0.36+
Compilation rk30sdk-pol 4,2,2 JDQ39 eng.zs.20140115.094810 test-keys
Vendor RK3066_R-BOX_ABDROID4.2.2-SDK_1.0.0_130308
Tell me what is this? how to do it right and simply root this model and where I can find new/better soft and not crash this dongLast edited by lmichal; 18 March 2015, 21:52.
Here is a thread about your model: http://www.freaktab.com/showthread.p...kernel-file%29
Yours has a different NAND chip, but that should not matter.
Hey Guys,
i'm very new to this. I bought a stick from a friend, he tells me its a MK808b, but it has Kitkat installed. It dont react to any kind of recovery boot, i've tried hundred ways to root it without excess, in the frontend the Tablet Version is only RK3066.
Im totaly confused what i have here, so i open it up, maybe you guys can help me to identify what i have here...You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
I've uploaded them with the Boardfunction, no matter why this isnt working propper...
I uploaded them again to a pichoster, here are the Links...
http://www.abload.de/image.php?img=euqka.jpg http://www.abload.de/image.php?img=m0ohb.jpg http://www.abload.de/image.php?img=dvpnj.jpg http://www.abload.de/image.php?img=2aryb.jpg
There was a rooted stock rom posted for your stick earlier in this thread. You can load it here: https://mega.co.nz/#!lNQGEDjC!5AWRdP...vqfLhvt6Qzo0jk
Extract and flash the img file using "Rockchip Batch Tool". I am sure you find a tutorial via google. You should be able to enter Flash mode via recovery button (the hole beside the LED hole).
Flash mode using the reset button:
If you do not ever see the flash tool say "Found RKAndroid MASS Storage USB"
Or reboot to flash mode does not work, then use this manual proceedure.
1) Have the USB cable unplugged.
2) Near the HDMI port are 2 holes in each corner. One is the blue LED hole.
The other in the corner is a reset button under the hole.
Use a paper clip or something to push the reset button in this hole.
I actually enlarged the hole so a paper clip would fit.
You will feel the button "click" when you are on it.
3) Hold this button down and while holding it, plug the USB cable from the PC to the OTG port on the mk808.
4) YOu should here windows BONG it found a new device. The LED will not light!
5) You are now in ROM flash mode. Read below for installing drivers.
Originally posted by phinc View PostThere was a rooted stock rom posted for your stick earlier in this thread. You can load it here: https://mega.co.nz/#!lNQGEDjC!5AWRdP...vqfLhvt6Qzo0jk
Find a PC with Windwos 7 or older. Windows 8 and up has driver problems with rk3066 devices.
(I really need to know if those models can run JB because of an app in development that needs flash swf compability in Android Webviews and no success so far at KitKat..)
Thank you very much in advance.
Originally posted by phinc View PostWhich model do you have exactly?
And some discussions like these: http://vondroid.com/threads/mk808b-d...e-6#post-67975
I'm almost certain it's the "MK808B REALTEK HTC-T011-V4", it comes with 4.4.2 and that really made everything harder for my work. I only need to know if there's any chance, even a remote one, to put JB on this.
Thanks for your attention
There are currently 2486 users online. 1 members and 2485 guests.
