MK808B clones, how to identify them.
MK808B with RTL NEED IMAGE
Brought from **** it looks like a realtek, I have been unsuccessful in flashing any images provided so far tested images MK808B Finless 1.7 ROM, MK808B V1 Clone Finless 1.7, MK808B V5 Prah 1.0, update_mk808b_v5.0_104j2104, update_mk808b_v409j2404_overseas_xbmc_bt, 808b_cwm_backup_4.2.2._16april, GEEKBUYING_update_mk808b_v5.0_106j2104, prah v5 1.1, Prahjister Rom 1.2, update_mk808b_v424j2424_overseas. need image file. any help???
Originally posted by Akure View PostBrought from **** it looks like a realtek, I have been unsuccessful in flashing any images provided so far tested images MK808B Finless 1.7 ROM, MK808B V1 Clone Finless 1.7, MK808B V5 Prah 1.0, update_mk808b_v5.0_104j2104, update_mk808b_v409j2404_overseas_xbmc_bt, 808b_cwm_backup_4.2.2._16april, GEEKBUYING_update_mk808b_v5.0_106j2104, prah v5 1.1, Prahjister Rom 1.2, update_mk808b_v424j2424_overseas. need image file. any help???
i have flashed multiple times.
Originally posted by prahjister View PostWith all the flashing going on it may take a 2nd flash to be successful. Try flashing the same rom twice...Sounds like you have a v5. So go the v5 or mine which is just a cleaned up v5 with some patches.
MK808B REALTEK HTC-T011-V4
Originally posted by phinc View PostDude, did you check out the 5 posts before yours? All 5 were about your device and there was even a firmware link. So try this, this should work: http://pan.baidu.com/wap/link?uk=255...00546&third=15 (rooted android 4.4 rom firmware)
Bricked flasing rom, have green status light in batchtools it goes into recovery without need to push reset buttonwhen plugged into otg, every rom faills to flash , I need to get it into MASK ROM mode to flash Nand chip, model Skhynix unsure if I short PIN 8 and 9 or shortpin 9 and 10 unable too find any info on this board. I have another stick same model only images work are T011 images. Unabe to obtain original stock image from seller. Anyone with stock image or any images for this model? also any help in putting this device into mask mode or flashing SD METHOD.
I have a HTC-T011-V4 and cannot flash as well. One thing I noticed is that the blue light stays on while in flash mode (previous models did not do this). Also there is a timeout before the stick reboots on it's own. I tried using the RK ROM Dumper and Flash utility. I was able to get the parameter file off the chip but was unable to get the system.img partition. I tried this on 2 different HTC-T011-V4 sticks with the same result. Is there a different flash utility/config we are supposed to use on this?
Edit - I was able to successfully flash this with the T005_T011_public_root_8723_2014109_V4.4.img. The Factory Firmware Tool v4.4 works with this rom as well. Does anyone know if there is a Jellybean rom for this? Also noticed that the display scale keeps defaulting to 95% after a reboot. Any way to get the settings to stick?Last edited by ddrop; 16 December 2014, 14:20.
Any help?
Originally posted by mjuti View PostHi guys,
Mine is the same as yours, recently received from AliExp.
Can I root this device with the custom rooting tool for any 808b even though it comes with KitKat?
I am also considering putting linux on it, so guys keep up searching, together we might find appropiate linux builds quicker.
I am now downloading the rom from baidu that srysry recommended ( sucks, slow like hell ) but firstly I'd rather simply root the device with the original rom to see how it performs.
Is the cooked rom performing much better?
Finally, how can I root and/or flash a new rom and CWM on a Linux pc? Or strangly we must run windows in a VM to play with Linux-based Android????
can you please help how to proceed with fw upgrade, rooting as CWM recovery?
i searched through several forums etc. but there are so many controversary information, i really do not know what to take. any help please, especially for this ( latest? ) clone?
thanks in advance
Now, to complain with my issue ...
Since I took another mk808b release rom as good as the original I did not dump the one that came with the stick (I know ... stupid me) and I started to flash it (was a JB from another mk808b with the same rtl chipset). The flashing went fine but I could not make the stick to boot after flashing. It kept starting in flash mode. After I found the KitKat rom and flashed (3 times) I made it to boot once and saw the stick working, but after a reboot the stick lights up the blue LED and that is it. I can still make the stick work once every 20-25 tries by unplugging the power.
Does anybody have any idea about what might be wrong? I saw that constant booting in recovery mode means a screwed up recovery.img but this does not seem to be the same issue. Defective board maybe?
Originally posted by xontab View PostCan you help me find a ROM for this MK808B clone?
Before I bricked it, it was running Android 4.2.2 Build "RK3028_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130911"
Thanks,
STPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Hi, i would love to have someone indentify this one.
More pics here
Android-version 4.2.2
Kernel-version 3.0.36+ Mon Jan 13 11:47:51 HKT 2014
Version: ADS2.1_RK3066_Public_V422_131224
According to this post it should be one of the following, since it has MT5931 & MT6622?:
Group 2:
-UG007: Mediatek MT5931 (Bluetooth v2.1: Mediatek MT6622)
-Rikomagic MK802 IIIS: Mediatek MT5931 (Bluetooth v2.1: Mediatek MT6622)
-iMito MX1/MX2: Mediatek MT5931 (Bluetooth v2.1: Mediatek MT6622)
-MK808B Clone v1: Mediatek MT5931 (Bluetooth v2.1: Mediatek MT6622)
-MK808B Clone v2: Mediatek MT5931 (Bluetooth v2.1: Mediatek MT6622)
Any suggestions? Love to have a tweaked ROM. I managed to root i with iRoot apk.
Originally posted by spinx View PostHi, i would love to have someone indentify this one.
More pics here
Group 2:
Any suggestions? Love to have a tweaked ROM. I managed to root i with iRoot apk.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostIf you find stock. Post and I will tweak it and apply patches. Just let me know if you want 1080
I believe i have managed to dump all necessary files here, please let me know if its not correct. I would also like to have 1080, overclocking, max performance etc like Finless rom's
UPDATE! I belive i did my homework
After countless hours of testing, i have med some great progress. My conclusion after indetifying the Wifi/BT chips was that its likely a UG007/-2 clone of some sort. Therefore i searched for all UG007 ROM's i could find and tried them all. Tested about 8-9 roms with various results and finally i belive i found the perfect one.
Kitkat 4.4.2 from here and filename rk30_dongle_mtk_4.4_140617.img
Flashedwith RKBatchTool and booted successfully with Wifi & BT! Even flashed a OC kernel with 1608-400-533 clocks using RKAndroidTool. So faar so goodLast edited by spinx; 04 January 2015, 15:17.
There are currently 3908 users online. 1 members and 3907 guests.
