will this work->Prahjister ROM 1.2 MK808(B)4.2.2 720 and 1080
MK808B clones, how to identify them.
Originally posted by smolf View PostYes, that is the one firmware i use , but netflix does not Work.
Have you tried the SnakeRom image from post #7 of the thread i posted before?
Originally posted by phinc View PostNo, this will not work. At least not without modification.
is my android a MK802? or MK802B
should i just install 802 or 802b firmware ?
need netflixLast edited by smolf; 10 September 2014, 20:56.
need netflix
You have a mk808b clone. You can start experimenting with firmwares from other devices if you want, but it is always a trial and error.
i found " SunVel_I808_mk808_upgrade.zip " on another site ,but that just hanging on bootLast edited by smolf; 11 September 2014, 14:05.
R-BOX from seller link
Originally posted by prahjister View PostIf anyone wants to send me a link to a latest stock firmware....i will put my tweaks and debloat them.
PM to me.
https://app.boxcn.net/s/fauaiyhnlp10tu950pb7
Can anyone identify this clone?
I've been trying to find ANY ROM that will work for my mk808b I purchased from geekbuying a couple of week ago. So far I have tried finless 1.7 (which bricked my box, I was able to unbrick by shorting pins 7&8), Kitkat 4.4.2 (result-wouldn't go past boot screen), 2 ROMS from thread on very new clones (lost kernel-see link above)(one was backup from someone's new box, another was from a Chinese seller)(result=blank screen/no signal). I contacted geekbuying for "original ROM" and they sent me finless 2.1 (result=2 penguins). I've done others (more a stab in the dark than actually believing the will work). I'm at a loss. I'm attaching pictures of my box if anyone might have mercy on my poor noob soul and help me out. I'll keep trying in the meantime...at this point I don't care what the ROM does if I can just get it back to factory....Thanks a billion!
Androset Bluetooth Mk808b 4.1 Rockchip rk3066 cortex-A9 (Amazon description)
I have the same box...
Originally posted by grindhouse View PostI just bought mine from G-buying as well with the same RTL8723BS Chipset....any luck on finding best custom firmware or XBMC version?
Also, is this a clone or real - mine looks like none of the pictures.
There are currently 4386 users online. 1 members and 4385 guests.
