MK808B clones, how to identify them.
    MK 808b with Realtek wifi/bt - Android 4.2.2- need a rom can play Netflix.
    I received this last week, Netflix is not playing at all. Tried an older neflix 1.8, 2.4 - they play for few seconds and freezes.
    I am new to this- dont know how to back up my stock rom before intalling a new one.
    CWM would work on this?
    I am attaching photos for review.
    Are there any information on this stock rom?
    Please help, the seller is not responding when I told them I am not happy with the product becuase they advertise it can play Netflix.
    I am on my own to fix this thing.
    Above 2 posts have the same device as I have.
    I have found this on the forum
    MK808B coming with REALTEK WiFi/BT solution (ORIGINAL)
    Probably someone who knows better than me can help?
      Hello, my friend gave me to dongles, non of them are working because of wrong firmware was flashed, could you help me. On box is written UG802 but on the mainboard MK809II
      Thank you
        Is thee a new firmware?
        Originally posted by haze View Post
        Hey everybody,
        my english may be Not very Perfect, sorry for that.
        my mk808b was delivered today. Thought i can just Flash it, but now there is no screen over HDMI anymore. Tried to Flash with different versions, nothing works. No load up screen..
        can you say me wich Version i Need?
        thank you!
        I have the same device, however the area where the RockChip is located is covered and I can't be a 100% sure but all the rest is the same. Is there a better ROM for this device?
        JC
          mk808b
          Originally posted by postaltaco View Post
          hello,
          im sorry if this one was posted already, my work blocked most of the picture and i cant remember if i seen it last night.
          any help would be greatly appreciated. i cant get any roms working
          sorry for the giant images
          Hi
          If you take off the insulation pad next to the bt chip (not the heat sink) and tell me if it says " netxeon V5" on the board, I can send you links posted on this forum for stock rom and a custom rom by dev. (if you havn't found any solution yet). I think you have the "original" as shown on my post.
            mk808b
            Originally posted by MrFriday View Post
            which rom would go with this. is this a fake
            Hi
            I can send you links posted on this forum for stock rom and a custom rom by dev. (if you havn't found any solution yet). You have the "original" as shown on my post.
              What type is this?
              Hello, received my device from **** a few days ago, wondering what version it is and which rom is best for it.
ID:	434388Click image for larger version
              Thanks!
                MK808B Identify
                MK808B Identify: Ordered from Geekbuying w/ chipset stated to be RTL8723. How Can I tell which version this is for Roms without opening ? Right now my wifi works great ~73mbps and I dont want to jeopardize the connection.
                ie: also, can anyone recommend the BEST custom firmware for this device as well as best XBMC version. thanks, jim
                  Download Firmware Fail
                  Hi
                  I got this MK808B from **** in July. It had 4.1 and from the seller I got a 4.2 image from this link they provided:
                  百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                  I used RKBatchTool v1.5 to flash it but when it was about to finish I got this Download Firmware Fail message and now the thing doesn't seem to work, I connect it and the blue light is on but the TV doesn't receive a signal.
                  I am attaching images of my device so maybe you can help with a stock 4.1 ROM or a 4.2 ROM that works for this device.
Name:	2014-08-21 08.06.21.jpg
ID:	434497Click image for larger version
Name:	2014-08-21 08.07.02.jpg
ID:	434498Click image for larger version
Name:	2014-08-21 08.10.09.jpg
                  JC
                  Update:
                  I installed the ROM in:
                  It seemed to have installed successfully but when I connect it to a VGA PC monitor (using a HDMI to VGA adapter) there is no image and monitor doesn't detect the MK. I assume it should work using the VGA monitor, right?
                  It means I only need the correct ROM, right?
                    Originally posted by jcvl View Post
                    [ATTACH=CONFIG]7601[/ATTACH][ATTACH=CONFIG]7602[/ATTACH][ATTACH=CONFIG]7603[/ATTACH]
                    I tested with my tv when I got.home and the same thing, no image and blue light on. No image when in recovery either.
                    I tried flashing the suggested ROM by seller and it did install but still no image. At this point I am trying with all ROMs I can find. Please help, otherwise I will have to buy another one from teh same seller mand try to backup the ROM and apply it here?
                    JC
                      Re: MK808B clones, how to identify them.
                      JC
                      Stock firmware
                      MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
                        I got if from the reseller **** china
                        [ATTACH=CONFIG]7458[/ATTACH][ATTACH=CONFIG]7459[/ATTACH]
                        Thanks!
                        I got if from the reseller https://app.boxcn.net/s/fauaiyhnlp10tu950pb7
                          Originally posted by abraham239 View Post
                          Think its rooted?, Il test it out and see how far I get with it.
                            I just bought mine from G-buying as well with the same RTL8723BS Chipset....any luck on finding best custom firmware or XBMC version?
                            Also, is this a clone or real - mine looks like none of the pictures.
                              Hey all
                              which firmware for my device ?
                              I tried
                              PC04401下载ROM
                              but i want to try a custome
                              Thanks in advance
                                Originally posted by smolf View Post
                                Hey all
                                I tried
                                PC04401下载ROM
                                Thanks in advance
                                Read this thread abou your device:
