MK808B clones, how to identify them.
    It is not a problem with the flash tool, just with cwm.
    Sent from my GT-I9100 using Tapatalk
      Hello again,
      meanwhile I flashed Finless ROM 1.7 with 1080p kernel and WLAN works fine now. Looks like version 2.1 is broken or at least not as compatible in general. But I am trying the 720p kernel tonight. Teamviewer is awfully slow for example in 1080p. Perhaps 720p is sharp enough (especially for office) - I will try and figure out. In the end it's quite obvious that it's not recommended to use the 1080p kernel with this chip. It was designed to work with resolutions like 480p. 1080p is 5.4 times more than 800 x 480 pixel (my galaxy s2). 720p is only 2.4 times more. By the way, antutu benchmark with finless 1.7 and 1080p kernel resulted in 11.000 points! :-) And CPU-Z shows 2 x 1000 mhz as core frequency.
      I tried xda's market helper, works fine. But I am not really pleased with the browser screen resolution. I cannot zoom with my k400r, only double-click and change a little bit of zoom level - not enough. That's a problem with all browsers I tried (google, chrome, firefox, dolphin). So, I will try to find a hardware device (tablet) with similar cpu power of the mk808b and change the build.prop (I don't remember the exact name of the file, but remember reading of it) to that. I think, the Galaxy S2 is not a good choice for spoofing because of the smaller screen resolution. Perhaps, if installing/running apps "think", there's a device with native 720p resolution, than they will optimize their screen output to that (browsers for example).
      Is there any possibility to get original german keyboard layout for the k400r? Or can I create it myself? An ist there any tool to fake multitouch gestures with this touchpad. It is able to, but only in Windows 8. But perhaps it's possible in Android by pressing CTRL while tapping or something like that?
        Don't change one file to the other one... MK808 is not a tablet. The build.prop has parameters like screenrotation, power off screen and lots of important things.
        You must choose exactly what are you doing step by step.
        Android TV Box direct from China. English & EspaƱol
          I tried to be very carefull by changing the build.prop to a "Samsung Galaxy Tab 2 10.1". Till now, everything is working fine. Antutu and CPU-Z are showing the right internal hardware parts but GT-P5100 as the model.
          If anyone is interested, here is the build-file (modified version of build.prop from finless 1.7 for mk808b original with 720p kernel)
          build_finless17_mk808b_orig_720p_gtp5100.zip
          To resolve the problem with the keyboard layout (i got us english but wanted a german one with umlauts) I simply installed external keyboard helper pro.
          But there's still the problem with zooming (in/out, pinch-to-zoom). finless 1.7 (android 4.1.1) is capable of zooming per mouse and I have activated that, but how do I have to configure the k400r/external keyboard helper to simulate a mouse-wheel-scroll or that function which triggers zooming? does anybody know?
          Oh, btw: 720p kernel is much faster. I compared antutu results and 1080p has been 41 percent slower in 2D graphical benches than 720p kernel. It is also easy to recognize in general for me everywhere (browsing, teamviewer etc.). I will keep 720p kernel installed. It's sharp enough on my LED-TV.
            Mk808B Netxeon V3.0 - Any custom Roms available for this?
            I have a limited knowledge of flashing android phones using online guides.
            This is my first look at these devices.
            I bought one from an **** seller for £33 and I received this item:
ID:	431459Click image for larger version
ID:	431458Click image for larger version
            I bought it as a gift for a family member for Christmas but at the moment it is not functioning well enough to be given as a gift imo. The wifi keeps playing up, one minute it is fine the next it will not function at all. I was trying to use XBMC Frodo (latest) and although some add-ons would work many would not.
            Does anyone know of any flashable roms for this version?
            Also if not does anyone know how I can change the loader/gui?
            Since this new one has a pretty crap mainscreen..
            Any help would be much appreciated.
            (considering getting rid of this and getting a minix if this is too much hassle.)
              mk808b rom help
              Originally posted by Blunt_UK View Post
              [ATTACH=CONFIG]4265[/ATTACH][ATTACH=CONFIG]4264[/ATTACH][ATTACH=CONFIG]4266[/ATTACH]
              you need the rikomagic mk802III rom. it works for the new mk808b models.
              there are other roms that work too, minix mk808b cfw by lewy. you will have to play around to find the one you like best. the mk808b model works best on a 720p kernel with 1080p emulation. be sure to load the correct kernel. you will need a rom flash tool like rockchip batch tool and drivers for your mk808b to be recognized by your pc. also, to put the device into flash mode, get a paperclip and poke the reset button opposite to the little blue light. watch some mk808 model flashing guides on youtube.
                Hi Thomas,
                Thank you for sparing your time to respond!
                I'll proceed with your advice and report back in due course to further expand this thread.
                  I need your help :\
                  I've bought a MK808B from Amazon.co.uk last week, from Afunta, but i just realized it was a clone after a flashed finless 2.1 for the original MK808B. It booted up just fine and i could surf through the UI for a liitle bit but then it freezes and i have to manualy reboot.
                  I've tried other rom's but it does exactly the same! It is fine for like 10sec but then it freezes and all the screen goes green x) And if i try to click the navbar it instantly freezes too :\
                  I dont mind to get back to the original ROM if someone could give it to me and i dont mind to loose bluetooth either :\ I just want to get my device running normal again :\
                    Where ca i download the firmware z2c
                    Whre can i find the z2c firmware to download it?
                    Originally posted by Javimetal View Post
                    I just got 7pcs MK808, you can see the new antenna and also the MEDIATEK WiFi chip.
                    Finless ROM will not work, I think he still did not work over this version:
                    I just uploaded ZERO Devices Z2C A2 firmware and it was ok:
                    If you don't like the new launcher you can flash Z2C A2 firmware, at least until Bob make a new ROM for this MEDIATEK chipset.
                      May be there?
                        Hi
                        Did you try a finless rom on it ? Cause i dont know if witch version is compatibel with this device any one let me know witch finless rom is for this device
                        This one is MEDIATEK WiFi solution, but I got some RT chipset too and they mount same antenna. Factory is going to change MEDIATEK to RT series again. MK908 never changed.
                        Also as I said before, now all of them comes with a new launcher, a rubbish launcher in my oppinion. This is why I recommend to flash ZERO Devices firmware or Finless if available.[/QUOTE]
                          Flash this on your device
                          https://mega.co.nz/#!6IkSHDyC!MbqUvy...PLcyGXW0qaablI
                          So ... I have tested pretty much.
                          With the original stock ROM "everything" worked fine. WLAN was amazingly fast (full 16kbit), but installing Playstore-Apps was partially impossible due to the unknown device.
                          I made a backup using an update.zip file. That worked fine obviously. I haven't tested re-flashing yet. I got the following files with this backup:
                          boot.img (16 mb)
                          data.img (1.5 gb)
                          kernel.img (16 mb)
                          misc.img (4 mb)
                          recovery.img (16 mb)
                          system.img (1.0 gb)
                          Then I followed Finless' readme step by step and installed his 2.1 ROM for the B-model with 1080p kernel. That worked fine too, but wifi is somehow broken. I can see networks around me, but only a few and connecting to my router is not possible anymore. At first it says "excellent" and while trying to connect "not in range".
                          I screenshoted the original stock rom system infos:
                          Android version:
                          4.2.2
                          Kernel version:
                          3.0.36+
                          rjh_V_402j2 #62
                          Mon Jun 17 10:41:13 CST 2013
                          Build number:
                          mk808b_v405j2
                          2013-06-17 10:41:36
                          I don't know what to do. The original ROM is useless because of Playstore limitations (device incompatible to some/many apps). The 2.1 ROM doesn't work (I need WiFi). Should I try 2.1 with 720p kernel. Or should I try 1.7 with 1080p kernel? Or should I try a clone ROM and which one?
                          Thanks for your help!
                          -edit-
                          Oh, and I tried to tether my WLAN from my Galaxy S2 phone over bluetooth. The pairing worked, the connection sharing too, but there was still no internet at the mk808b.
                            I tried many Firmware, and my Mk808b (in exactness as on your picture) worked only with these
                            1. Zero Z2c (B2-version)
                            2. Neomode mk802iiis_neotv_cr_2_0_20130601
                            3. Rikomagic Mk802iiis Android 4.2 update by chinagadgetsreviews.blogspot.ro
                            All ather -- crushed
Name:	2013-12-13 11.13.06.jpg
ID:	431546Click image for larger version
Name:	2013-12-13 11.12.59.jpg
ID:	431547Click image for larger version
Name:	2013-12-13 10.37.55.jpg
ID:	431548Hi I bought this cozyswan mk808b from amazon last week...worked real good but last night It got on "android"...tried again 5 mins later "android"...left it over night and it hasnt fixed itself so can you guys help me out?
                                R-BOX MK808B clone using AP6210 WiFi chipset
                                This post just gathers the info I found here about a MK808B clone/fake/revision using a RK3066 with a AP6210 WiFi chipset together in one location... perhaps the OP can be updated to include this one ( the 4th or more clone ) as well so everyone doesn't have to read the whole thread to find it.
                                First I'll quote the post of pics/thumbnails posted by andip71 ... My device is identical with one exception, mine has Toshiba memory instead of Hynix.
                                Originally posted by andip71 View Post
                                Hi all,
                                referring to my thread:
                                finally I also opened the device and this is what I got.
                                Somebody ever seen that?
                                The following quote has the link to the ROM for it... it's R-Box branded with JB 4.22. The ROM that is linked is already rooted but doesn't include a superuser app... You may also want to edit the build.prop file to spoof a Samsung or other to allow more apps in Play Store to be available... this ROM version is one version newer than what came on my unit I just got November 24, 2013...
                                Originally posted by huene View Post
                                New Update: My seller gave me a new link.
                                The AP6210 chipset will substitute the RK903 in future because of better wifi stability, he told me. Maybe one day we get a custom FW for this new clone...
                                This FW works for Wifi and Bluetooth and has the same kernel but a new build number,
                                it ends with ".170924 test keys":
                                https://www.dropbox.com/s/1glfmhuj0g...30828_V1.0.rar
                                FYI... I did try Bob Finless's MK808b v2.1 ROM when I was attempting a recovery on the device... WiFi doesn't work as typical of the clones... I didn't test BT since I wasn't going to use the ROM after finding out it was incorrect for the device.
                                Last edited by rdsok; 21 December 2013, 21:43. Reason: Insert missing attachment images
