MK808B clones, how to identify them.
Originally posted by phinc View PostThis site loads forever and it seems to be a pdf file!?
Can you please upload it somewhere else?
Here is the file in another site. Hope it works now.
Originally posted by steveboy2 View PostRE: New Clone?
yep, thats what I've got too. Didnt save the original ROM [like an idiot], decided to try a new setup since the original did not always boot successfully - went from Google TV to the Android screen back to Google TV, etc.
now Im stuck with a bricked device.
I have tried all of finless' ROMs 1.6-> 2.1 for original, clone 1 and 2 - no luck.
The nearest I get is with the 2.1 original (and 1.7 original) which install but leaves me without BT and Wifi. Others get stuck with two Penguins top left at boot.
Chip set is MT5931SA, MT6622N
Came with Android 4.2
Help! Think I have tried every rom I could find or so it seems ....
I have the same device with MT5931SA, MT6622N but mine came with android 4.1.1.
There's any ROM available that has working WIFI and BT?Last edited by makelele; 28 September 2013, 10:28.
CYX Tech MK808b - Anyone see this one before or know what Rom to use?
Hello all,
I have been trying to figure this one out for a few days as it does not match the description of the other clones and of course WiFi and Bluetooth are gone (I'm using an Ethernet to usb adapter currently) I can flash anything 808 or 808b and it will work without wifi or blue tooth. If I try the 1.7 for clones I get stuck with the two penguins. Same with Sunviel. I cannot find any info on this one . It is a Rock-chip 3066 and the stamp on the board reads CYX tech mk808 v1.120130614
I know this is an 808b becuse I checked the factory rom before I flashed it and forgot to back it up. Just curious if anyone knows anything about this one and can reccoemnd a decent working ROM as I'm not having much luck
Thanks for any assistance as I'm trying to prove to my wife that a $50 stick can replace a laptop... she is winning this round and laughs at Android... I need to prove her wrongHelp!
Can anyone help identify my device? Doesn't seem to be exactly like any of these. It has MediaTek wifi/bluetooth chip but otherwise looks most like the original. Neither antenna is attached to the plastic casing and one of them isn't attached to anything at all other than the soldered end.
Link to Amazon: http://www.amazon.co.uk/Afunta-Bluet...eywords=mk808b
Originally posted by lefty989 View PostCan anyone help identify my device? Doesn't seem to be exactly like any of these. It has MediaTek wifi/bluetooth chip but otherwise looks most like the original. Neither antenna is attached to the plastic casing and one of them isn't attached to anything at all other than the soldered end.
Originally posted by phinc View PostIt is obviously that one: http://www.freaktab.com/showthread.p...ll=1#post89798
Thanks for your help again.
Thank you!!!!
Originally posted by lefty989 View PostOops, my bad I assumed the OP was up to date.. Sorry for n00bish-ness. Going to try flash the stock 4.2 Rooted ROM for now. As look as it's rooted, runs smoothly, works with Plex & wifi/bluetooth works I'm happy. Only reason I flashed a ROM was due to it coming unrooted.
I think I have the same version as you I have managed to root it using this guide:
and downloading these:
Does your stick play video perfectly ?, I noticed mine drops the odd frame on just about all video from usb or sd card.
I would like to make a custom rom using the bt and wifi driver and maybe a finless rom if poss.
I still cant get cwm to work, I think its due to an incompatible recovery console. I wish never got a bloody clone lol.
Originally posted by bazray View PostI think I have the same version as you I have managed to root it using this guide:
I'll be happy with rooted stock if I can get it to work.
Originally posted by lefty989 View PostOn stock everything streamed great via Plex direct play, I didn't try anything from USB though. Imito custom ROM was pretty laggy.
Ah. Is yours the Afunta one? (mine is).
I've been taking the ROM found in the quote below as stock.. Maybe it isn't the same then..
This is such a pain. Wish the damn thing came pre-rooted.
Originally posted by Fabiop View PostHi,
For those of you that have the new found mk808b clone and have lost the original firmware, the supplier gave me the link to it.
I uploaded it to my device and it went back to normal. Wifi and BT are working
Maybe we'll have custom ROM for this clone as well!
Cheers
There are currently 3602 users online. 0 members and 3602 guests.
