MK808B clones, how to identify them.
Originally posted by ygolonak View Post[ATTACH=CONFIG]4848[/ATTACH][ATTACH=CONFIG]4849[/ATTACH]
this is my device, could someone please tell me which rom works, I'm desperate, thanks
See my post #150 ( not the best ROM in my opinion ), post #154 also has links to some... and my post #161 has a link to the one I ended up using before I switched to a quad core device.
Originally posted by rdsok View PostThere have been several links to ROM's that support yours with the RK3066 and using a AP6210 WiFi/BT chipset... This is the info you need to know when looking at other ROM's to try.
Originally posted by ygolonak View Postthanks for your answer, probe all of them, and my unit turns on the light but does not start anything, the screen is black, can not be the same device. or maybe it is broken.
Check that you have the HDMI cable plugged in good on both sides... also test on another brand of TV just in case your TV is partly at fault. If you have another PSU you can try that supplies enough power... check that also.
Originally posted by rdsok View PostA bad device or bad cable aside... and assuming you did flash them properly following the instructions
thanks for your answer, checked cable, power, another tv. I did step by step as manual flash and does not turn screen. It seems as if the video output malfunction. if it were not for that once saw two penguins would think that the video output is wrong. thanks
Help with Ditter V19 Rk3066
I bought and android tv Ditter V19 Rk3066 but since I have it, it doesn´t work, I need help, and img or a restore archive. I only get something with MK808 Finless 1.7 but it freeze in the begining showing GOOGLE TV or the android with recovering data and sudenly stops. I have attached an image. Thanks
CAUTION!
If you have this hardware:
Do not flash any of the standard AP6210 firmwares, this stick seems to refuse to boot on any of them. If you have this device, it would be very helpful if you could share a backup of your firmware (how to backup).
Here the photo
[ATTACH=CONFIG]5073[/ATTACH]
Anyone has backup from same clone of MK808B ?
There are currently 4325 users online. 0 members and 4325 guests.
