HPH RK3288 KitKat ROM v1.7 by mo123
    Changes
    Stutter-free playback in SPMC
    Latest apps
    10-bit color support for 4K videos
    23.976 framerate videos play better
    updated ffmpeg
    4096 resolution videos play correctly
    Some ui display optimization
    Solve the problem with can't play certain video games
    Increase CPU speed
    Can install latest Youtube from Play Store if 1080p is needed.
    Also better SPMC to use - Here
    (Will be merged with Kodi maybe next week)
    Will also make a dual-boot ROM with Kodi.
    Have been doing testing for the past week.
    Please donate if you can and find the ROM useful to help with further ROM development.
    Download Link: Here
    UPDATE 10-08-2015: HDMI Passthrough Fix for People having problems Here
    Flash after flashing ROM and running it for the first time.
    Flashing instructions same as previous version below.
    HPH RK3288 KITKAT ROM v1.6 by mo123
    Changes
    Code:
    - SPMC 15.0 beta 1 included (with cache patch)
    - LeHome Assistant app works
    Download to phone or tablet for a great remote experience(v1.7)
    [URL]http://hphtv.t-chip.com.cn/ljzsupload/index.php[/URL]
    - 1080p Youtube with download option, floating window on homescreen, playback with screen off(Have to enable Xposed modules to make account login work)
    - Universal Storage
    - Wifi Tweaks
    - Init.d Support
    - Removed Bloatware
    - Newly build, based on 19/04/2015 code
    - NTFS, NFS support
    - Gamepad support
    - HDMI Hotplug fix
    - 32-bit Color Support(don't know if it works)
    - Fix green color problem & x265 videos black color banding problem
    (Can decrease brightness on your TV or in Android Settings to improve it further, too much brightness and x265 videos don't look good)
    - Fixed no hdmi sound issues with some equipment
    - Sleep Mode works and doesn't reboot device
    - D*lby Digital+ Support(change equalizer settings in app)
    - SD Card cache fix for improved performance, no need for SD Card Booster apps etc.
    - MXPlayer included for best video playback and performance(includes custom codec for DTS/AC3 support)
    - MusicMatch - for Music playback with lyrics and album art support(other music apps either don't allow folder support, album art or lyrics and are paid apps)
    - CPU Temperature in Status Bar(Activate it in Xposed Installer app after installing Xposed framework - Select input/temp0 for correct temperature display)
    - 3 Launchers - HPHTVLauncher, Nova(for Lollipop look) & Solo Launcher(very customizable, run patch to change dockbar icons and remove desktop icons)
    Code:
    [B]- [/B]Update RKVideoPlayer
    - Supported Dolby TrueHD and DTS-HD MA in MKV/TS.
    - Fixed memory leak issue in BDISO.
    - Fixed HTML5 playback issue from offline source.
    - Update to rk3288_kitkat_rel_v2.15
    - IP Multicast Support
    - HDMI CEC(might only work with certain equipment, buttons)
    - MCE Remote Support, Mele F10
    - Media:fix the mediaserver crash probability
    - Gallery2: Not Free BitmapTexture Manually
    - Void Memory Leak (bmp)when decode image with BitmapRegionDecoder
    - Decode Original Bitmap by BitmapRegionDecoder for JPG and PNG only
    Before Installation
    - Make sure USB Power saving mode is disabled for the USB Port you use to flash the device
    - Use a PC Back USB Port and not ones from the front or a laptop
    - Disable/Pause Antivirus software for 10 minutes to not interfere with the flashing or cause high disk usage.
    - Make sure device was connected to PC before in flash mode and drivers were installed
    To Install drivers
    - Connect device with OTG Port and cable to PC
    - Now connect the power adaptor
    - Before plugging the power adapter into the device, hold a paperclip into the reset hole of the device, keep holding it while connecting the power
    You will hear a 'click sound' that Windows is now recognised the USB device.
    - It will ask to install the drivers or install it automatically.
    For Windows 8.1
    - Download here and copy to
    C:\Windows\System32\drivers or use the included bat file.
    Install then with the 'Rockchip Driver Assistant Tool' in the 'Flash Tool & Driver' download at the bottom
    Installation Instructions
    In second tab of AndroidTool(Upgrade Firmware)
    - 'Firmware' - To select single image file
    - 'Upgrade' - To flash the firmware
    After Flashing
    Leave plugged in to PC 3-5 minutes after flashing to
    - Erase 'data', 'cache' &
    - Install Apps
    Then unplug and connect to TV/Monitor
    After Booting
    - Select Solo Launcher
    - Turn on wifi/Ethernet
    - Use TW to root
    - Install framework for Xposed Modules & activate modules
    - Use HPH Tweak app by mo123
    - Restart again
    Now Solo Launcher icons at the bottom will be sorted and icons on homescreen removed
    SPMC will now also cache to RAM for better streaming to help with buffering
    MXPlayer will now also pick up 3rd party Codec to enable DTS/AC3 audio
    - In MXPlayer also enable RGB 32-bit Color(not sure if it makes a difference)
    Download Link: Here
    Pass: HPHv1.6
    Flash Tool & Drivers: Here
    (Use 7z to extract ROM)
    HPH_Tweak app by mo123: http://bit.do/5mPt (Can type it into a browser and download onto your device)
    For DNS Support
    - Use Addfreetime app to activate your IP
    - Add Addfreetime Android DNS Settings to DNS Forwarder app and activate on boot
    Can sign-up here for $1.99/m to view content not available in your region
    How to get Harmony Remote Working on RK3288
    http://freaktab.com/forum/tv-player-...her-3288-boxes
    What is Xposed Framework?
    http://www.gogadgetx.com/xposed-fram...-modules-list/
    Extra Xposed Modules
    http://www.hongkiat.com/blog/xposed-...s-android-rom/
    Official Kodi/SPMC Remote App for Android Phone/Tablet
    https://play.google.com/store/apps/d...=org.xbmc.kore
    Test Build of Kodi with HD Audio support for Nvidia Shield(still wip) - Can test it on RK3288 and provide feedback and logs to Koying
    Streaming Apps(Use at your own risk)
    Here & Here
    PS: Can also boot to Recovery with 'Reboot' app and install extracted *.img file ROM through Recovery - load from external SD then a PC is not required to flash.
    Can you guess the changes?
    First we must guess the password!
    Can you please put it here or PM me?
    Thanks.
      Thanks.
      File name, same as for v1.5 ROM - HPHv1.6
      Didn't put a password, because I wanted to see who first downloads the ROM and ask for password
        Thanks. I was pretty close with an uppercase 'V'
        BTW, how do we flash this single img file?
        Does AndroidTool supports it, or is there some other method?
          - Install Apps
          After Boot
          - Use TW to root
          - In Terminal app type
          'su'
          cd /system/bin
          sh customer
          - Restart again
          - In MXPlayer also enable RGB 32 bit Color(not sure if it makes a difference)
            i have put my hph box away and went back to the matricom gbox q (with a custom rom) as it works best on my TV. For some reason i have audo issues with hph and my set up on every rom i have tried so far. I will give this rom a try later today hopefully it works. Not to mention the lack of number keys on the remote, makes it impossible to map any dedicated playback buttons on my harmony remote.
              Waaaa ! big thks mo123
                mo123
                I am enjoying 1.5 on my Firefly, GREAT addition for my Samsung smart. Will be installing v1.6, have one uestion (sorry no backward p, wife educated me with glass of water). The 8.1 drivers, is there a change here, for I am using windows 10 IoT and have found no difficulties yet with the existing windows 7 tools.
                  Originally posted by cappybob View Post
                  mo123
                  I don't think so.
                  I think it is for 64-bit Windows 8.1 users.
                  I also just use the normal drivers and everything works fine but haven't tested on Windows 10 yet.
                  You can use the kernel/resource.img from the latest Firefly ROM from April 2015 and it should work.
                  But I can compile a new kernel too if it doesn't work.
                    The rom works fast and stable.
                    But maybe that's due to my 65+ games not yet restored lol.
                    Anyway, no more sound issues for me, like on 1.5 version.
                    Going into sleep mode doesn't reboot anymore.
                    Maybe it's a placebo, but the rom feels much smoother than before.
                    Will test for a few more days and report my other impressions.
                    Thanks again for quality work!
                      Luckily there is more than enough space for game data, don't think so many games can fit on stock 2GB userdata.
                      I hope all the sound issues are fixed, but if anyone encounters more sound issues, please provide a log so it can be send to the manufacturer and get fixed.
                      Here are instructions - http://freaktab.com/forum/tv-player-...-get-a-logfile
                      Koying(SPMC) is now also testing HD Audio, so in future HD Audio on SPMC on RK3288 devices might be a possibility.
                      Will also try to make my first app to add extra features to the ROM that users can easily change eg.
                      - advancedsettings cache for SPMC
                      - MXPlayer AC3/DTS Codec
                      - Solo Launcher Tabs/Folders, Layouts - Maybe someone can share theirs after adding tabs for video/audio/settings etc and creating a backup in Solo Launcher and share
                      the backup of the 2 files in /sdcard/SoloLauncher
                      - Bootanimation changer
                      - Buildprop changer for people with 720p displays so screen is not stretched too big.
                      But will take some time to learn and create.
                      In a few days will get Lollipop support and Windows 10 is also on the way, so some exiting things for RK3288 TV Boxes.
                      I didn't create any Linux ROM for this as it takes too much work and there still isn't any hardware accelerated video working, if it gets released by user mac_L1 then I will look at it again. But can combine my v1.5 ROM with this one if anyone want to dual-boot.
                        so this means
                        "only" at stock player?
                        RK3288 Devices
                        - Overview BOX (LINK !)
                          mo123
                          Impressed, loaded my o/c Kernel and no problems as of yet. Just getting started, impressed truly by what I saw upon boot. My Firefly seems to really like what is happening.
                          Thanks---cappybob
                            No audio with this rom in my living room. But hooked up to my pc monitor I get audio. Very frustrating.
                              Did you enable 'HDMI Bitstreaming' in Android - Settings?
                              Please try to provide a log when you try to play music.
