HPH RK3288 KitKat ROM v1.7 by mo123
Tahnks mo123 for new rom.
Stutter is free but passthrough is not working.native player is not working. Mxplayer is working in sw not hw.maybe I,ve not installed correctly this rom.after fash rom I have rooted this rom by file update.zip after restart installed hph tweak mo123 and after this in xposed installer I,ve installed latest framework after restart passthrough is not working ofcours the first was not working.native player was too.I,ve not play any video with native player and mxplayer is switch on sw not hw
Just tried the ROM and can confirm that video playback is as close to perfect as I have seen yet out of the box so to speak and the version of SPMC posted works wonderfully.
1080p Youtube gives the best playback yet and with just about no stuttering whatsoever.
Everything is zippy too.
Last edited by bluesmanuk; 02 August 2015, 17:49.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Then videos will play with H/W+ support and not SW. H/W doesn't work on all devices, but H/W+ is much better.
The native Video app is very basic and not a lot of people use it. It doesn't work at the moment but will try to fix it and find out what the cause is.
Have to download external codec and enable it in MXPlayer to get DTS/AC3 Passthrough audio.
Don't know if all receivers will work correctly with passthrough, can't remember if I included a patch.
Will fix it in a new ROM if there are lots of problems.
Try using latest Kodi merged with SPMC and enable expert settings and at acceleration, disable rkstagefright and keep Mediacodec enabled.
http://mirrors.xbmc.org/test-builds/...rmeabi-v7a.apk
Can also enable sync to display in video settings. If you have a modern TV, the TV will change resolution to the video playing eg. 1080p @ 24fps, 1080p @ 30fps, 1080p @ 60fps etc.
Can also use an advancedsettings.xml file for Kodi to cache more to RAM for streaming issues like buffering.
There is also work underway to have HD Audio passthrough support with new codecs in Kodi for Android.
Video playback is great. Press 'o' to see video file info for video playing.
All the 4k video files people had problems with play fine for me without any dropped frames.
Originally posted by bluesmanuk View PostJust tried the ROM and can confirm that video playback is as close to perfect as I have seen yet out of the box so to speak and the version of SPMC posted works wonderfully.
But Youtube from the Play Store has 1080p automatically, if floating window support and download option is not necessary.
SPMC - That version from the link is now merged with Kodi.
So lots of problems people had with SPMC will be fixed as it's official Kodi but with SPMC's Mediacodec support.
In Kodi settings, enable expert settings, acceleration - only enable Mediacodec and in video settings enable 'sync display to video' to change TV resolution to best match the playing video for smoother playback.
I think my ROM now has the best RK3288 Kodi video playback.
If only manufacturers could sell devices that already work so well instead of full of bugs.
For MXPlayer, go into settings, decoder and enable H/W+ for all.
with latest kodi with advancedsetting.xml I can,t have passthrough with spdif and hami bitstream.
Youtube - The included Youtube app also have 1080p support. Have to go into settings and set 1080p for wifi streaming and 'enable all resolutions' then it will work. Otherwise it will only show 720p.
I have found that the best video playback is with all 3 enabled.
With just mediacodec there can still be some stutter.
I am surprised that the manufacturers and vendors don't approach people such as yourself and employ you as contractors to help them make better ROM's.
It's not as if they cannot afford it and better software results in more sales.Last edited by bluesmanuk; 03 August 2015, 15:57.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Hi mo123
I haven't any problem with beta hph 1.5.3 with passthrough mxplayer switch on hw and passthrough is ok native player and spmc too.my problem was stutter with 4k file and some 1080p mkv file and dts hd audio passthrough was not working hd audio (downmix to dts)
in open hour 1.0.27 with mx player<1.7.32 with hw decoder I had passthrough with dts dd and hd audio but mxplayer>1.7.32 not .it switch was on sw or hw+ which not support passthrough.I don't know why?my problem was stutter with 4k and some mkv's file and bluetooth wasn't working.
Originally posted by opengl1971 View PostAfter flashing i rooted then ran exposed installer but i found the exposed modules not useful for me (root cloak-fake id and such )
If you only care about video playback do you have to install exposed framework or the exposed modules to get the maximum video performance ?
It doesn't affect video playback.
There are currently 2062 users online. 1 members and 2061 guests.
