HPH RK3288 KitKat ROM v1.7 by mo123
    Originally posted by m1pnk View Post
    well im using now Mo.... the dogs bollocks.... smooth as silk
    The best 4K 80mbps playback on RK3288 devices
    Where other devices stutter, this ROM plays the same videos fine on HPH devices.
    I'm really disappointed in all the RK3368 boxes I've seen so far.
    Very little quality control, and the basic things that should work like video playback has lots of problems.
    And then companies just forget about fixing those problems and move on to other chips like AMLogic, MStar, Intel & then back to Rockchip.
    Rockchip actually produces very good CPU's, but the manufacturers combine it with other lower quality components that cause bottlenecks and don't optimize the firmware, very sad.
    At least the new HPH RK3368 will also be of high quality and people will see that spending a little more money is worth it in the long run, than saving a few bucks and having lots of problems afterwards.
      My hph box it's almost finish to replacing my minix x8h plus, I only missing two thing a working hdmi cec and full working Linux kodi then I thinks it will be my last box for long
        Hi mo. Thanks for the new rom version.
        Before I flash it, I would like to ask something.
        Recently I've been experiencing some random reboots while WiFi AP in turned on (v1.6).
        Sometimes it reboots afer only 10 minutes, but no more than 30 minutes.
        If I turn WiFi AP off (while still connected to the same router), the box can stay on for weeks.
        So the question is, did you changed something is relation to that in your v1.7 version?
        Or should I maybe try a lollipop version? btw, when will final v1.0 come out?
          Wifi AP: Is your router far away from your TV Box or what kind of configuration are you using?
          Can you use another cheap router in-between your modem/router and TV Box to give a better signal or use as an access point?
          Do you use the normal round oval antennae on your HPH or the flat 'squirrel tail' antennae that works much better?
          Just normal wifi for me works very good. I don't use a Wifi AP.
          If you can tell more about your network, maybe someone else can also help.
          Maybe take a logcat(catlog app on Play Store) of your device and post it, so Nagrace or someone can check it and find out if there is something mentioned that cause the freezes/reboots/disconnections with the Wifi AP
          Lollipop firmware still has some bugs, that's why I haven't released a new version yet.
          Want it to work very stable without problems before I work on it again.
            Thanks for a reply.
            I'm connected to a LAN, so distance shouldn't be a problem, and no need for repeaters/extenders in that case.
            I use stock HPH WiFi antenna which worked great until now, but I'm not sure if I could find any other to mount instead of that one.
            Normal WiFi works good for me too, in sense of box stability, but because the box is about 10m away from router, speed is very slow.
            But that way I can't use WiFi AP, since they can't work together.
            I also tried BlueTooth tethering, and it works just fine, but 3Mbps is slow as hell compared to my LAN speed.
            Today my issue is manifesting in the form of instant reboot when my other device initiate some download over WiFi AP.
            So it's difficult to get a catlog, since it's erased across reboots. Or not?
            Anyways, this is not my preffered way of connecting to the internet, and should only be temporary.
            My other device which is also 10m away from router can't even connect to it, and it doesn't have a LAN port.
            So I ordered usb to lan adapter to work arround that issue, but it will take at least 3 weeks to arrive to my place.
            If there's any other info about my network configuration I should provide, just ask and I'll check it out.
            Meanwhile, I'll check how lollipop handles WiFi AP and report back here.
            EDIT: even though a beta, lollipop handles my WiFi AP just fine. No reboots and full speed ahead!
            It has some bugs, worst of them not being able to mount my external usb hard drives I heavily depend upon. And only 1 working usb port
            But it's not a big deal since right now I need the box as an AP only, and all other tasks I'm dedicating to my other tv box.
            Sorry for cross-posting, I just wanted to insert my edit here where I started my question initialy.
              Does it support hd audio passtrough on rkvideoplayer?
                I'm 99.9% sure that it doesn't only on SPMP from what I've read on FT.
                  Hi mo123,
                  great rom. I have found only one problem: hdmi passthrough with spmc and dolby make only noise on my Onkyo tx-nr535 amplifier.
                  I boot Your rom from sdcard in my MK902II device.
                    Thanks for a reply.
                    What other box do you have that is so much better that you would relegate your rk3288 to the lowly role of AP?
                    You can buy new AP's, high rate N ones for under $10 on aliexpress, maybe ****, too. Maybe even AC ones.
                    Cheers!
                    -SB
                    Currently using U-BOX R89 with mo123 v1.6.
                    Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
                    Pipo M9S -- CrewRKTab custom rooted 4.4.2
                    RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
                    ----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
                      Originally posted by pirmar View Post
                      Hi mo123,
                      UPDATE 10-08-2015: HDMI Passthrough Fix for People having problems Here
                      Flash after flashing ROM and running it for the first time.
                      Please test.
                        Hi mo123,
                        Will it be a dual boot with Linux or maybe you wait for a sound solution for the Linux version
                          Originally posted by Shadi86 View Post
                          Hi mo123,
                          I'm still waiting for better playback and sound fix for Kodi to release new Linux firmware.
                          Doesn't help if I release and then a few days later it is fixed.
                            1+
                              hi mo123
                              unpack your firmware(v1.7) and flash with new resource.img and kernel.img and passthroug is not working with native player mx player and spmc.amp teac ag-d500
                                Originally posted by mghb View Post
                                hi mo123
                                Are you using Dolby TrueHD or DTS HD MA?
                                In SPMC, Dolby TrueHD or DTS HD MA is not currently working at the moment.
                                Did you install the custom codec for MXPlayer that enables passthrough DTS/AC3?
                                Please try this firmware and see if passthrough is working Here.
