HPH RK3288 KitKat ROM v1.7 by mo123
Originally posted by mo123 View PostI need 2 testers for my new ROM.
It will be a Lollipop ROM with latest Rockchip Kodi support.
I need people to test video playback and passthrough support.
Want people with HPH RK3288 devices that had passthrough issues on previous firmware.
Will finish the ROM in a day or so.
Will we have this for a nice xmas gift maybe :P
You can test the v1.0 first.
I plan to update the ROM since people say Netflix isn't working on v1.2 of the ROM.
Hi mo
Do you know Wich kodi will work best for this rom?
Btw I have tested your latest lollipop, I have do quick test and the rom got freeze 2 time when I browse the menu, I'm also hard tester, when I test a new rom i always browsing fast in the menu, I switch to my apps and back to UI fast few time to see how stable a rom is, it's how it's get freeze, will test more when I have more time
For Lollipop you have to use NTMC 16 beta 2(included in my LP ROM) or RK Kodi 15.2 that is optimized for the newer VPU drivers.
Does anyone experience stuttering on the HPH NT V6B unit? I have the 4G/32G unit with v1.7 rom. I read some info on it on another thread. Link below. I use my player to stream ripped Bluray from MakeMKV video files from lan. So it is high quality. The video does not buffer so speed is not an issue, only micro stutter.
Originally posted by janplank View PostDoes anyone experience stuttering on the HPH NT V6B unit? I have the 4G/32G unit with v1.7 rom. I read some info on it on another thread. Link below. I use my player to stream ripped Bluray from MakeMKV video files from lan. So it is high quality. The video does not buffer so speed is not an issue, only micro stutter.
What is the resolution,framerate, bitrate & codecs of your videos?
They might play better with 'Video' player or SPMC.
Are you using MXPlayer?
You can try a Lollipop ROM with Rockchip Kodi support
Rockchip Kodi has an optimized setting for 23.976 framerate videos and play 4K videos more smoothly.
Hi
I use SPMC, the latest version from the web. I have not tried MXPlayer yet. The resolution normally is 1920x1080, 23.976fps & mpeg4 codec according to MakeMKV. Would the lollipop rom be better?
There are currently 2356 users online. 0 members and 2356 guests.
