DTS Passthrough not working on 1.7 rom, neither MX-Player or SPMC (UPDATE 10-08-2015: HDMI Passthrough Fix also not working on DTS Passthrought) it used to work well at 1.6 rom. any fix?
HPH RK3288 KitKat ROM v1.7 by mo123
It should fix the passthrough issues.
Normal stereo sound from TV speakers should work if connected with an HDMI cable to TV and USB speakers plugged into AV port or USB Audio adapter should also work.
I'm trying to make HDMI sound work but I have to enable it for both HPH NT-V6 model and HPH NT-V6 with HDMI-IN Recording which is a bit difficult since the box with HDMI-IN Recording has lots of extra audio code and settings.
in your test rom : spdif passthrough is working in rkplayer and mxplayer , but sadly not for spmc....... also switching off the box reboots it (beelink R89)
you're almost there bro.... keep it up. thanks
Originally posted by gridlock View Postyup bro.... i changed the settings in spmc 15.0 , but to no avail
but must first register.
In android settings/sound/sound devices manager ensure it is set to HDMI Bitstream.
In xbmc set the audio output to 2.0 (setting to 5.1 causes lag on sd streams)
Enable passthrough checked.
Enable dolby digital transcoding is checked.
Also try this older Kodi
Also try official Kodi 15.1Last edited by mo123; 09-08-2015, 16:50.
Originally posted by manero View PostPerfect working Beelink R89 + spmc-armeabi-v7a_14.2.0 ======> Goood!!!
Uninstal xbmc e spmc default firmware
fix micro stuttering !!!
Thanks mo123!!!
Have you tried SPMC 15 beta 1?
Or does 14.2.0 work better?
Still need people to test HD Audio, HDMI passthrough and different versions of SPMC & Kodi.
Then I'll make a custom ROM and improve it even more.
thanks for the effort mo123 :
Originally posted by mghb View Posthi hd audio works(dts master hd and dolby true hd)with this update?
I applied all the passthrough patches(which includes better compatiblility for HD receivers) from Rockchip.
If HD audio is not working, I'll try something else with a different ffmpeg codec & RKVideoplayer also.
Zidoo is also going to release a RK3368/RK3288 Kodi with HD Audio support.
They will later release the code, and their version of Kodi can be used instead of SPMC.
If the HD Audio, improved video playback codec is better & cleaner than SPMC, it might even make it into official Kodi release.
SPMC 14.2.0 work better .....Good!
So your micro stuttering is gone?
[QUOTE=mo123;n523923]
I don't know, that why I need people to test it.
If the HD Audio, improved video playback codec is better & cleaner than SPMC, it might even make it into official Kodi release.[/QUOTE
hi mo123
with new update hdmi bitstream can't passthrough dts and dd with optical dd and dts work but It has bug with pcm sound. D true hd and dts master audio does' n support with this update.
dear mo123
why don't you port open hour 1.0.27 to beelink or hph?with 1.0.27 d true hd and dts master audio works perfect but bluetooth not.
There are currently 2746 users online. 3 members and 2743 guests.
