HPH RK3288 KitKat ROM v1.7 by mo123
Porting the OHC ROM will cause issues with
HDMI_IN not working, Remote Control App not working, manufacturer settings etc.
The OHC is an abandoned device and not updated anymore.
Everyone is now porting UGOOS ROM's to their devices.
I will try to port the video player app with HD Audio but don't know if it will work because the OHC firmware files are a lot older than other devices firmware and might have compatibility problems.
Luckily Lollipop firmware is becoming a lot more stable and has vast audio/video playback improvements.
That will solve all the audio issues.
we are waiting for your next firmware that supports hd audio too.
Hi mo123,
I tested new rom and obtain some strange behaviour:
a) SPMC preinstalled don't work with hdmi passthrough
b) home media center don't work with hdmi passthrough
c) Kodi 14.0 alpha 4 preinstalled work well with passthrough
d) Kodi 15.2 stable work with passthrough, but audio is not stable. Every few seconds fade away and return. It's a shame that this new version don't work as expected.
e) Shutdown don't turn off my box, but simply reboot it.
Thank from Your effort.
The reboot on shutdown thing is likely down to the fact that people will be using non HPH RK3288 devices to use the ROM, so the kernel and resource files will not have the correct settings for other boxes.
You would need to flash the kernel and resource images for your particular box for such features to work.
Do sound work the same or is one version better than the other?
https://mega.nz/#!WxwjAZBR!KtVSfWLCP...pLL6-v442mjDGc
http://mirrors.kodi.tv/releases/andr...rmeabi-v7a.apk
Then also test latest stable SPMC here
http://www.semperpax.be/owncloud/pub...&id=Za7c7uitXV
Make sure you use the same sound settings for each version.
In Android Settings - HDMI Bitstream Enabled
In Kodi - Passthrough enabled
Also test MXPlayer with DTS codec downloaded in it's settings.
Can you test this Kodi 15.1 with passthrough patch & Kodi 15.1 fron kodi.tv website?
2) kodi-15.1.1-Isengard-armeabi-v7a. Passthrough work, but with sound fade and return problem
3) SPMC 15.0. Passthrough don't work
4) MX Player with dolby 5.1 test file: Only internal sound with hw+ and software codec (Normal stereo sound on amplifier). With hw codec only noise like using kodiapp-15.1-armeabi-v7a-debug.apk and SPMC
1) kodiapp-15.1-armeabi-v7a-debug.apk. Passthrough don't work
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Change different sound settings in Android - Default,SPDIF,HDMI Bitstream and test
the different Kodi,SPMC, MXPlayer & default 'Video' Player.
mo123
RockChip released their R-Box 3288 SDK today and with this, their current work for RK3368. Not sure if this SDK is also for the RK3368 box or not. http://wiki.t-firefly.com/index.php/...id_lollipop/en
Do you perhaps know if someone compiled the SDK and have an update.img(or separate img's) ready to upload?
Can you upload the kernel folder, I see the separate kernel folder in bitbucket is older than the one in the LP SDK?
I will try to download later but will take several hours for the full file.
Do you know how to get HD Audio RKVideoPlayer patch from Firefly/T-Chip or other company perhaps?
mo123
Will do what I can tomorrow in the afternoon. There is an image for 5.1 in the wiki download, images from wico have aiways been separate boot.img and kernel.img. Haven,t checked yet, I will though. Will upload the Kernel rk3288 box sdk for you, I have several accounts available. Also there are several files available for the Tronsmart RK3368 SDK in this RockChip build. Bedtime
not a problem--cappybob
mo123
Found time tonight RK3288 kernel 5.1 SDK 148M https://mega.nz/#!iU0AlByJ!iTBOYhzkN...pqAx3OG4NBkG1Q. let me know if works, for all others will keep posted on Mega until Head Commit changes.
later cappybob
later cappybob
Now I can try to use it with the Tronsmart RK3368 SDK I already have.
Do you perhaps know what difference there can be between Tronsmart 100mbps & 1gbps lan version, as they only released 100mbps lan version SDK?
Is it a simple kernel driver or build option in config file?
Don't think Tronsmart will release a new SDK to the public again.
At least Firefly helps people a lot.
Will try to compare Firefly(should have 1gbps driver) & Tronsmart kernel(only 100mbps driver).
Already build a custom ROM for HPH NT-V8 RK3368 device and it's running very smooth now.
Will try to make a custom kernel boot also now & for RK3288 HPH NT-V6(which is very similar to Firefly).
I still need a compiled update.img for RK3288 from Firefly Lollipop source, will wait for someone to upload.
There are currently 2387 users online. 0 members and 2387 guests.
