Originally posted by bloodnock View PostTried removing all usb connections to no avail. install on betas 3 4 5 still dont get past the wasser animation startup on beelink r89 16gb
Please let me know if it works
wasser great
i can confirm your latest statement
tried on mk902II - beta 1,2 booted ok, beta 3,4,5 boot loop
flashed 2.0.9.a and then upgrade to beta 5 and it booted fine..great
wifi and BT not working on mk902II but i don't care, don't use it...
great work
going to try other functions...
great rom as always from you...
Originally posted by bloodnock View PostTried removing all usb connections to no avail. install on betas 3 4 5 still dont get past the wasser animation startup on beelink r89 16gbOriginally posted by wasser View Postit sounds partition problem here; as workaround please flash 2.0.9a firmware first and then 3.0.0b5Originally posted by lonely2k5 View Postwasser great
flashed 2.0.9.a and then upgrade to beta 5 and it booted fine..great.
I've got different question:
Is it possible to update from beta 3 to beta 5 without loosing all data in userdata MTD partition? IIRC when you do not flash misc.img uderdata partition won't be reformatted. Is it still true?Last edited by Gormar; 25 June 2015, 20:16.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View Post
Good to know. I have upgraded from Wasser's 2.0.9a and I wasn't aware that is the right way.
Wasser
Originally posted by gffmac View Post
Confirmed, installs fine now.
Wasser
Hi Wasser, excelent work with Lollipop ROM.
If you need testing with Tronsmart R28 Meta (same as Beelink R89) and 4K television (HDMI 2.0 - 2160p60) please let me know!
Just some things i've tested:
Currently 2160p30 sort of works (some screen corruption while moving the mouse but if you hide the mouse pointer it looks OK) and 2160p50 and 2160p60 dont work (used to work with 2.0.9a).
Also tested KODI 15.2 Isengard and it works quite nice (as it has its own nice mouse pointer theres no screen corrupion on 2160p30).
Also here's hoping you implement Lollipop's frame rate switching (as mentioned on KODI 15.2 isengard release notes) on our little boxes
Great work and thank you very much for your dedication on developing this ROM
PS : Forgot to mention -- using 3.0.0b5
hi wasser,
i am having exactly the same issue as described by xiizoo, also experiencing ac3 passthrough problems in spmc 15.2
cheers, i appreciate all of your effort on this rom.Last edited by dodit; 26 June 2015, 23:52.
There are currently 3599 users online. 1 members and 3598 guests.
