Again, this Lollipop Beta 5 is AMAZING! However:- Skype is crashing with C270 Logitech webcam/microphone.
- Google Hangout video works fine, but microphone does NOT work.
Skype video was the very last thing fixed on KitKat (2.09), so it would be nice to get this working early-on in Lollipop, since just about everything else works amazingly well.
Thanks for the great work.Tronsmart Orion R28 Meta. Wasser Lollipop Beta 5 (very stable). Video Out: 60" 1080p LG Plasma TV-HDMI 1.3. Audio Out: Default (stable). Remote In: TaoTronics TT-MK005 Air keyboard/mouse (keys repeating). Apps: Kodi (stable), Plex (stable), WatchESPN (Stable), Amazon (Stable).
Hi guys,
Wasser fantastic job!!!
My system
. Samsung UA55HU8500 Ultra HD Smart LED TV (Series 8, 4K upscaling, 55 inches, 3840 x 2160 200mhz)
. Samsung Home Theater HT-F9750W (1,330W, 7.1Ch; Vacuum Tube; Dolby Digital Plus, Dolby Pro Logic I/II, Dolby True HD, DTS HD/Neo, 3D Sound Plus)
. Beelink R89, wasser-3.0.0b5, KODI 15 (from play store), sPDIF optical cable connected to Surround system 7.1, HDMI cable connected to TV
wasser-3.0.0b5-lollipop-beelink-r89-rk3288 is working great but there are 2 major this still not working.
1.Passthrough AUDIO Option
Android configuration: Settings - Sound - Default Output
On Android settings I only have the following options:
. Default Output (this is the selected one)
. Default Output (again but only can select the 1st)
. HDMI Bitstream
KODI Configurations: KODI - System - Audio - Passtrough with AC3 and DTS activated
Result: Movie sound is in cuts. If I deactivate the Passtrough in KODI sound is ok.
2.Resolution
Android Settings: Display - HDMI Mode - 1920x1080p-60
My tv supports 4k at 3840x2160-20/30/50/60 but it R89/Wasser3.0.0b5 cannot recognize it and the best that work is 1920x1080p-50
Beside that just a few minor notes:
. Some apps make the screen rotate to vertical mode (not good at all considering I cannot rotate 65'' TV)
. ABOUT the device still shows wasser-3.0.0b3 (I even double checked if by mistake the download was B3...)
It would be nice to solve this issues...
Once again thanks to Wasser and to all test community.
T.
. HDMI Bitstream
Originally posted by thipolito View Post. Some apps make the screen rotate to vertical mode (not good at all considering I cannot rotate 65'' TV)
Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
T.
I always seem to have problems with Pluto.tv app to view the guide. Works perfectly on Google ADT-1 but I haven't seen another tv box working properly. Wasser rom it rotates the screen and makes it unusable.
Originally posted by freakdave View PostWasser rom it rotates the screen and makes it unusable.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Batfink32 View PostIs YouTube working for everyone? I can't get it to play properly?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 2284 users online. 1 members and 2283 guests.
