Hi Wasser!
1. I noticed on RC1 that the original remote control "OK" button is not caught in MX Player or BS Player during playback - just nothing happen when I press OK. It should show a playback controls on.
2. In torrent-tv app (and in few other apps) there is another problem. On start it is not possible to move a cursor. First I need turn on mouse mode and then point on any button. After that it starts to work.
These are user experience problems with navigation now.
Hope you can reproduce it.
3. I have a box connected by lan and share inet using wifi hotspot feature.
Hotspot works fine, but when it turned on and phone browses in inet there is some weird stuttering during video playback from iptv.
When I turn wifi off - stuttering dissapears.
It can be caused by some process that stutter all the system. I noticed few times a lagging in the user interface - sometimes it just is frozen for a 100-300 ms.
BSPlayer plays video more accurately than MX Player. Cant see any video through MX Player - a lot of frame drops. I have MX Player Pro + NEON acceleration. HW+ is enabled.
Anyway - you made a great job! Keep on!
I have Beelink R89B/16GbLast edited by andreyh; 15 August 2015, 15:03.
I decided to give this a try but after flashing I get the recovery screen with:
e: failed to mount /cache (invalid argument)
e: failed to mount /metadata (no such file or directory)
formatting /data...
formatting /cache...
formatting /mnt/sdcard...
Rebooting...
After rebooting all I get is the boot animation which does not change.
I've erased the flash and tried again but nothing I try seems to be able to get this to boot correctly.
My feedback for version 3.0.0 rc1
Generally smooth in operation as usual.
WiFi/Ethernet speeds good.
No SPDIF output at all, whether using Kodi 15.0/1, SPMC, MX Player, BS Player.
When I do switch to SPDIF then many files don't even play at all. They load to the interface but nothing else happens.
If I then switch to default audio output the same issues exist and normal sound and video playback is only restored after a reboot.
As reported in an earlier post by andreyh earlier, playback in MX Player is quite choppy at times, even with SD files and BS Player does play files better, even though at first it often reports that is cannot play a file before proceeding to do so.
It's very rare to see MX Player not playback just about everything.
It's very rare to see MX Player not playback just about everything.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by Xufar View PostThank you very much for your work Wasser, I'll PM you with a Netflix account soon.
Thanks again for your netflix account, without it i could not fix this netflix issue
Originally posted by wasser View Post
mxplayer works fine for mw in HW mode, please change it to HW mode and dont use the custom libffmpeg!
After checking there are troubles with 1920x1024 full HD videos in MX Player - HW mode doesn't play them and switches to SW with stuttering.
Confirmed.
There are currently 4179 users online. 0 members and 4179 guests.
