    Originally posted by bluesmanuk
    I find that 1080p Youtube can have stuttering but have found this to be the case with every ROM and box that I have tried.
    I have also found that even when selecting 1080p, Youtube will switch to a much lower resolution for no reason.
    OGYoutube works better but you will still find some micro stuttering at 1080p.
    Youtube through Kodi works best but so far I have found 720p to be the max I can get.
    However, the difference between 720p and 1080p seems so marginal that I don't care that much when 720p gives smoother playback.
    I think that's what I've found also. Why would YouTube stutter? It's as if it loads so much then stops, then loads then stops, virtually unwatchable for me . It does happen on every ROM (I'm not moaning about Wassers great Rom) . Such a basic thing that this box struggles with :-(
    Sent from my SM-G925F using Tapatalk
      I only get micro stuttering.
      Nothing major and no sudden stopping but it is noticeable to my eyes.
        I get stopping for a second or 2. Connecting to Ethernet seems to help. It's a strange thing.
          Do you have a couple of examples as I can try then and see if it is replicated?
            Just every 1080 YouTube video. Plays ok for around a min then stops for 2sec then plays for 30sec then stops for 2secs on and on. The buffer is way ahead so it's not loading, it's almost like there's a bottleneck in the CPU when on Wifi or something. It happens on MOs 1.7 Rom also with OCd kernel.
              Thanks bluesmanuk, but not sleep fonction
                Just use the remote for sleep.
                A single quick press of the power button should do it.
                  https://play.google.com/store/apps/d...and.screen.off sleep funktion work
                    Bravo, wi-fi work very good for the first time on Wasser Lolipop firmware! My device Tronsmart Orion R28 Pro, very fast and stable, good job, thanks hero!
                      Originally posted by AndreyZ1980 View Post
                      thanks AndreyZ1980, I'll try
                        thanks Wasser for the great work.. Hope in your next build there is going to be another revelation.. thats a working remote for rk3288 box on Lollipop.. Thanks again and more grease to your elbow... Gracias
                          ı remote control mele f10 pro...
                          But not work soft lock screnn app , because remote gyro obstacles happening...
                            Hi all i wondering if its possible to donwload torents and stuff content directly to an external sd card in this firmware and how to it if yes?Thanks
                              Solved
                              This app is nice works;
                                Is it possible to upgrade this firmware using the Settings -> About -> Check for updates? If not, is this feasible for the future?
