Originally posted by gridlock View Postbluesmanuk, that is really weird coz it's working so damn fine with me bro.... i even started watching movies that i thought i'll never ever watch like Cinderella 😝....
seriously bro , it's working like a charm with me...
That's a good thing then
Hi Wasser!
Fix for "OK" button for MX Player is in file
/system/usr/keylayout/ff680000_pwm.kl
Just replaced the first line
key 23 ENTER
with this one:
key 23 DPAD_CENTER
Now it works just fine for me on 2.0.9a
I hope that the same fix is needed for 3.xLast edited by andreyh; 25 September 2015, 10:53.
HDMI 5.1 passthrough audio works fine with MX Player. MX Player audio and video work great over wired network Samba share. No SPDIF audio at all. The SPDIF light doesn't even light up on the hardware. None of the Kodi, SPMC, Wasser Kodi players work well. Wasser Kodi does have HDMI audio passthrough but the HDMI connection drops out with my Pioneer receiver. I'll try it with my Yamaha receiver tonight. My Dishanywhere Sling Player app works much better with this Lolipop rom. Thanks wasser!Last edited by amclean123; 25 September 2015, 21:18.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Just tried rc3 rom ... It's very fast!!!
Seems we can't use nfs with kody or spmc.... Someone can use it?
EDIT:
My bad... NAS issue.
Brillant rom so far!!!!Last edited by roolmapool; 26 September 2015, 19:57.
Originally posted by Kytrix View PostHi !
Do you know to update from 3.0 to 3.0 without loosing data .?
at first reboot I see formating /data, sd_internal ...
and I lost all my applications and settings :/
Unpack firmware and flash single partitions.
Originally posted by Kytrix View PostThanks mo123 !
for me there is no changes with surround sound :/ with this rc3
I still get :
some small cuts in sound with kodi 15
big noise with smpc 15
both with passtrough and AC3 & DTS enabled.
There is not sufficient support for passthrough in Kodi for Rockchip devices at the moment.
Will have to wait for a new SPMC version to come out or use new Rockchip Kodi with passthrough support, but think that is only for RK3368 devices at the moment, but optimized firmware will hopefully also be released for RK3288 devices to be able to use Rockchip's Kodi.
There are currently 2589 users online. 1 members and 2588 guests.
