I can't go back to Rc1. After flash , it stays at the wasser logo.
Originally posted by chrisarchon
I can't go back to Rc1. After flash , it stays at the wasser logo.Last edited by chrisarchon; 21 September 2015, 12:56.
Originally posted by chrisarchon View PostI can't go back to Rc1. After flash , it stays at the wasser logo.Last edited by Gormar; 22 September 2015, 20:38. Reason: AndroidTool button to wipe NAND is called "EraseFlash"RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by chrisarchon View PostI don't see a "Wipe" button. Maybe you mean "EraseFlash"?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by doc539 View Postgreat rom!... but how to install Xposed framework and xposed apk?I want to use fake wifi connection module.
to sir wasser and bluesmanuk ........ after applying the fix steps wasser mentioned (overwrite the /system/etc/audio_policy.conf before you flash the resource-spdif-ll-19.09.img) ; SPDIF PASSTHROUGH using mxplayer 1.7.40 WORKED....... don't know how (based on previous comments by bluesmanuk!!!). but for spmc 15.0 still no sound (don't know about other versions , but kodi 15.0 spdif works but with weird slow video playback) .
don't know what to say. thank you wasser for such an amazing rom and hopefully you can do the same fix for spmc or share a working version.
Originally posted by gridlock View Postto sir wasser and bluesmanuk ........ after applying the fix steps wasser mentioned (overwrite the /system/etc/audio_policy.conf before you flash the resource-spdif-ll-19.09.img) ; SPDIF PASSTHROUGH using mxplayer 1.7.40 WORKED....... don't know how (based on previous comments by bluesmanuk!!!). but for spmc 15.0 still no sound (don't know about other versions , but kodi 15.0 spdif works but with weird slow video playback) .
I can only report my own findings based upon my use and tested many files but if it works for you then great.
Hopefully others can test and confirm their experiences.
Please test it with other videoplayers too.
Mxplayer 1.7.40 (but not with that installer-like codec). i'm using the codec file developed by xda developers ( the one you usually save in the download folder and then enable from the mxplayer codec settings) (actually mxplayer 1.7.40 recognizes it when you open the player for the first time. That is as long as you copy it or download it the download folder)...
This rom actually transforms the beelink R89 to a whole new level due to the amazing video quality... and the spdif passthrough support of course 😊
hopefully sir wasser can provide us with a working spmc version , since (as you've mentioned before and tested by me) got no sound (the tested version is spmc 15.0 and strangely kodi 15 gives dts and dolby digital sound via SPDIF passthrough, but with horrible and slow video playback)....
Wasser , the God of roms . thanks a million
There are currently 2607 users online. 0 members and 2607 guests.
