wasser For RC4 only. When HDMI audio passthrough is selected HDMI audio loses sync with the video. RC3 didn't have this issue. This isn't an issue when SPDIF audio passthrough is selected or the default audio is selected in Android Settings.
Update. So far this seems to only apply to one application (Dish Sling Player) so I wouldn't waste any time on it.Last edited by amclean123; 04 October 2015, 01:01.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by wasser View PostHi all,
lollipop wasser firmware version 3.0.0 rc4 is released. For more infos, please take a look at the first post.
Enjoy and don't forget to post feedbacks
Thanks,
Wasser
Since RC2 I cant direct play videos with AC3 or DTS using PLEX.
Last version it works fine is RC1.
I am using Tronsmart R28 Pro.
Other than that, in RC4 WiFi works again, it didn't work with all other RCs. It was not a problem for me because I am using LAN.
OTG port not working, last time it worked I think was in RC1.
Originally posted by doc539 View Postyesterday I installed " Xposed firmware " and since then I got bootloop !
... I had to open the cover of the TV box and connect the wires to the motherboard the two small circle because the only way I could reinstall the wasser firmware RC4
There doesn't seem to be any version of Xposed that will work with LP on these boxes at the moment.
I've tried quite a few and like you have had bootloop.
We will just have to wait for a compatible version to arrive from somewhere.
http://forum.xda-developers.com/show....php?t=3034811
BTW. Xposed is badly needed.
There are currently 2718 users online. 1 members and 2717 guests.
