Great work on the ROM. Installation went smooth. 3.0.1 was my first installation of this WASSER Lollipop Rom so I was not sure if there was any other prep work to be done other than flashing the image file. (Had the Finless ROM before) Pass through using the Spdif port works great. HDMI works except for AAC. HD video is super smooth. I am using flymouse which the setup reports as a 2.4GHz keyboard. Therefore, no onscreen keyboard. Does anyone know how to correct this?
Originally posted by Snoopy12345 View PostPerfect Work Wasser! Thank you!
But i have problems with my ethernet. It reconnects the whole time. Are there different network chipsets? Got Orbsmart S92. WiFi is perfect.
Greeting
Snoop
Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by scooter2014 View PostWasser needs title updated to ROM GOD. 😆Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by 4WheelSpyder View PostGreat work on the ROM. Installation went smooth. 3.0.1 was my first installation of this WASSER Lollipop Rom so I was not sure if there was any other prep work to be done other than flashing the image file. (Had the Finless ROM before) Pass through using the Spdif port works great. HDMI works except for AAC. HD video is super smooth. I am using flymouse which the setup reports as a 2.4GHz keyboard. Therefore, no onscreen keyboard. Does anyone know how to correct this?
Originally posted by gridlock View Post
i think you just have to activate the hardware keyboard from android settingsRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Someone with Wasser's 3.0.2 LL ROM would be so nice to test H.265 Main10 video playback preferable in MXPlayer? For example this one.
Video should be fluid and not slide show in SW mode.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostIn fact he has to deactivate hardware keyboard to see virtual one on screen. But after your advice he should be able to experiment and found correct setting.
then disable that hardware option in (keys and inputs methods) and see if you will have the virtual keyboard...
Originally posted by 4WheelSpyder View PostThanks for the advice. Hardware was disabled but the keyboard did not show up. When I plug a wired USB mouse in the virtual keyboard appears. I believe the firmware sees the fly-mouse as a keyboard and automatically assumes that is what is to be used. Not a big problem since I have another fly-mouse with a keyboard which I can swap with this one.
There are currently 2616 users online. 2 members and 2614 guests.
