I wish i could but it worked for me on two devices. I installed 3.0.2 as a clean install initially. I had horrible playback issues and sound drop outs. I also had the random display flashing issues other users reported so i did a clean install of 2.0.9 which worked perfectly. As a punt, i figured i would try 3.0.2 again and just did a firmware upgrade from 2.0.9 to 3.0.2. For whatever reason this worked and yielded smooth playback with no audio dropouts using Wassers Kodi (i did not try mx player as i don't use it).
Since this worked for my R89 i decided to give it a try on my Ubox. I first did a clean install of 3.0.2 and had the same playback issues as above. I then installed 2.0.9 and then did an upgrade to 3.0.2 which again yielded smooth playback with no audio issues.
I'm sorry I can't explain it! It could be random luck or it could be that a 2nd install of 3.0.2 does the trick for whatever reason. In any case it's certainly easy enough to try out to see if it fixed your issues
