    Hi Wasser!
    Can confirm that the flickering issue is gone.
    Video playback is absolutely flawless.
    Have a problem when using Firefox: the screen sometimes turns into 2/3 white (upper part) and 1/3 black (lower part). Navigation bar is not available then. Have to use keyboard or right mouse button to go back. Btw. is there any keyboard hotkey for taking screenshots?
    One thing that I'm missing from previous versions is the close all apps X button in overview.
    Thanks again for your great work!
      Originally posted by uli-hh View Post
      Hi Wasser!
      I can confirm that bug too. You have to exit (not close) Firefox and reenter again then you have the full screen.
      This also happend with 3.0.2 as far as i remember.
      @wasser: Do you work on getting xposed working ? Some guys over at the arctablet forum have found out that its the rockchip framework including the Rockchip APPS causing the problems. And I think they might be right cause my rk3288 Pipo P4 Tablet works with xposed and CM 12.1 (Missing the Rockchip stuff) while it doesnt with the pipo lolipop firmwares.
        Originally posted by minonano View Post
        Great ROM, working well even with Kodi, only question is why I cannot watch hockey on cast stream.com? Seems always no video with rk chips, but always works with any and all amlogic chips. Any idea why?
        Can anyone help please, why this streamcast app only works with Amlogic and not RK chips, maybe change in video settings?
          Thanks for the update Wasser! With v3.0.3 I can finally use my R28 on a daily basis. Movies plays perfect with Kodi and HDMI Pass through works good. I no longer have audio dropout with either Spotify, Kodi or Youtube. I'm using Logitech K400r keyboard which is working perfect, except with Kodi. When I'm hitting the enter button, the option under the mouse pointer is selected, not the option I have chosen with the arrows. Does anyone else have the same problem or can help me fix it? About the multi window support, the calendar/clock in the right corner is showing wrong timezone, Kodi won't open in full screen and some other apps wont maximize.
          Thanks for the good work!
            I've got similar problem with clock in right side of the task bar in multi window mode on mo123 LP v1.3 (LightBiz OS). Therefore I think it is RockChip error and in China they didn't noticed it because they hardcoded their own Time Zone (UTC+8).
            Maximizing to fullscreen mode for some apps in multiwindow mode is a pain. Sometimes I need to select "minimize task bar" icon just after launching those trublesome. Other time when task bar is hidden "alt + tab" to lunch an app from previously used help with that problem.
            RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
              it seems your timezone setting is wrong. The default timezone setting is Berlin in my firmware. You have to set it to your timezone. The calender/lock uses the system default timezone in my firmware and it shows correct for me.
              Wasser
                Wasser
                I'm using the same timezone as you. Got the time and date to stick now, however the date has the format year:month:day instead of day:month:year, the time is always showing in 12-hour format, even though I select 24-hour and the name of the months seems to be in German, no matter what language I choose. From the picture you attached it looks like everything is working, so it may just be a problem on my system.
                Do you manage to open Kodi in full screen with multi window enabled btw? I tried the "tricks" Gormar said in the post above with no luck.
                  Think you wasser for you firmware update.
                  Kodi is in this firmware? or where is a good version of kodi please?
                  I would update my tronsmart 3288 this weekand,
                    Have a problem since the 3.0.3 release with es file explorer: the background of the folder screen is black and the fond for the folder/file names is also black
                      Change the theme to 'Classic'
                        Thanks for the quick solution. But that's anyway a kind of weird. On all my 3 other android devices there is no problem like this with es file explorer.
                          Does anyone uses a torrent client with this software?
                          I was using "transmission bt" in KitKat but it is not compatible with Lollipop.
                            Hi Wasser,
                            In the 2.03 rom I was able to configure my harmony remote as a tronsmart Vega-s89h which allowed me to have considerably more buttons to play with and configure for kodi such as sms search etc anyway having flashed your latest rom the remote no longer functions. I have looked at the keylayouts inside the system folder but it seems to be deeper than that - Seems like the ir commands are not present in the kernel any longer. I am guessing the “ir key value” for the remote would need to be added and the kernel re-compiled? I have been using the firefly wiki as a resource and come to this conclusion but could be completely off base! Could you possibly shed some light on this or point me in the right direction?
                              I'm using Flud BT client under Lolipop without problems.
                                Hi, i used 2.0.9 fine. Tried 3.0.1 and 3.0.3 but wifi is not stable. It would keep switch between off and on. As a result, unable to connect for use. Ethernet works fine. Is anyone having such wifi issue. I tested on both dlink and asus ac router.
